Question about Alesis Fusion 8HD Sound Card
No sound ...
I just turn on my fusion but i get no sound from the speakers or the headphones, just a small buzz form the speakers (something like a/c sound : zzzzzzzzzzz) and i can hardly hear a tiny sound coming from the notes i play .
My monitors are ok .What can i do ? Is it possible to reboot it or something else like a restart ?
Go into global settings, choose the MIDI settings and make sure the very first box is checked. I lost my sound and had a similar problem and just did some troubleshooting and once I clicked that box, my sound returned. Hope this helps.
Posted on Apr 07, 2009
I was having an issue with my newly purchased second-hand Fusion 8HD, the "best answer" here went along way in helping me solve my headphone sound out issue.
I'll describe the issue & then the solution:
When I switched on the 8HD there was a very low volume level from the left analog output (headphone & main), accompanied by a crackling sound. The right outputs always worked perfectly.
After 30 minutes of "warming up" the 8HD by letting a demo tune run at half volume, the sound level of the left output would begin to match the right output level & the crackling would die down significantly.
This situation only allowed for tolerable use of the 8HD & I was convinced I was gonna have to replace the sound card, however the fix is so simple!
Heres what worked for me:
Boot Up 8HDPress GLOBAL
Select MIDI
Now hold PLAY & RECORD while POWERING ONThis may take a few seconds
Let 8HD fully boot upPress GLOBAL
Select MIDI
Now POWER OFF - again!
Again hold PLAY & RECORD while POWERING ONAgain this may take a few seconds but its so worth it!
I hope this works for you too.
Posted on Jun 13, 2012
My Marshall MG50 DFX Has an awful buzzing sound that comes out of it after startup.
I would check C22 and C24 the main smoothing capacitors. They can fall out at worst or just have bad solder at best.
Mar 20, 2017 | Music
I have a djm 400 and it has started producing a buzzing sound through the speakers. I can take the same speaker cables from the djm 400 and hook them up to my backup mixer and the buzzing goes away. What...
Does it buzz through cans? (headphones). Try listening on headphones (turn off any amps and speakers) on cue to each channel you use and to the master output. is it stil there? if so it's an all round earthing fault. If it's all good through the cans (sorry...I mean headphones), try it with the amp/s on again. If the buzz is back it souds like the screen on the main audio output connecters has come off inside.
It's a quick fix, but if you have never used a solder iron, take to someone who has.
Jan 07, 2011 | Pioneer DJm 400 Professional DJ Mixer
My speakers are currently turned on, at normal volume. Whether I try to play music or not, a buzzing noise comes from the speakers.
your power supply is bad for the speakers giving them to much power or there bad speakers plug some headphones up and see if it makes the buzzing if it does then you have a power problem with your computer or sound card
Mar 17, 2010 | Audio Players & Recorders
When I turn my speakers on there's a buzzing sound all the time, and when I put my headphones in, it's even louder, (in the headphones of course). What can I do???
Check your sound card hasnt came loose, make sure there is no router or hub of any type near your pc. nothing much after this check wiring for shorts. if you listen to the music to load all the time it can damage the amp. try plugging headphones into where the speakers normally go on your pc , see if the hummms there if not then its just your amp on its way out.
Dec 02, 2009 | Altec Lansing VS4121 Computer Speakers
Buzzing sound coming from TV Speakers and any external speakers
change your pre-amp ic sure it will work. or maybe cold solder from the board.
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
I got new speakers for my laptop, and they don't work!
go to the control pannel, then go to sounds and audio devices, then click the audio tab across the top. under sound playback, choose your speakers as the default device. solution only works like this for windows xp. good luck
Apr 29, 2009 | Ozaki DT-500 3-Piece Speaker System...
My QC2 right headphone starts to buzz, like a vibrating sound
It is a blown woofer in the headphones that is causing the vibrating. Because when a woofer is blown is will develop a small tear, this tear will get bigger over time and cause that "vibrating" sound that you hear. Lucky for you joenfrancis your headphones are still under warranty so they will replace the headphones for free. Hope this helped!
Feb 20, 2009 | Bose QuietComfort 2 Consumer Headphones
Macbook 2 ghz white no sound
this has been answered, just stick something small in the headphone port, best to save money, or take in a local apple store.
Jun 03, 2008 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
No sound
turn your speakers up and moisten your finger. touch the jack plug that inserts into the pc, if you hear the speakers buzz/crackle then they are ok. If not I would try a new lead if possible, else speakers are u/s as if headphones work then speakers should as well as use the same output from the pc, just amplify it unlike headphones. You could also check in the cpanel to see if your speakers are set to speakers and not headphones but to be honest I cant see this stopping the speakers altogether.
Mar 22, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Alesis Fusion 8HD Sound Card Logo
282 people viewed this question
Top Alesis Computers & Internet Experts
John Bolton
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
