My polaroid46" HD widescreen lcd Television may have been affected and or damaged by a recent (9-9) thunder and lightning storm. I can't get it to turn on-when I hit the on-off button with the DISH TV remote the blue light in the lower right hand corner comes on for a few seconds, then a red light comes on for a second and then the blue light returns; this repeats for ever. Is there a fuse in the television that can be replaced or is there a re-set button that I haven't been able to find? The DISH receiver seems to be fine. Please advise. Thank-you! Ned Roche, 413-441-3583 or email: eroche@ adelphia.net
  • J. Valen Mar 06, 2012
    Hi Everyone,
    When my TV was hit by a thunder storm, several components of the power circuit board were burned out. I discovered that there is a Buss type fuse (small glass tube w/ wire-like element attached to metal caps on each end) which, if burnt wire-like element is gone. It can easily be pryed out & replaced w/ same type from radio shack. If that doesn't work then most likely, like mine, components of the power board are fried.
    Master:
  • 505 Answers
Did you Check the fuses. thanks viper
Posted on Sep 14, 2008
    President:
  • 1,952 Answers
Due to lightning storm high voltage passed into ur television circuit...normal voltage is 230v is an input to the television..due to lightnin high volt may be in millon of volts passed in it...so it may affect ur main board..better u call service man to rectify it...mostly change ur main board..it wont work in future
Closed caption is on and neither the remote nor the menu setup options for cc are working. I tried resetting to factory settings but no help. Advice?
Search Results
    [PDF]Instruction Manual
    static.bhphotovideo.com/lit_files/62319.pdf
    TFTV1525 ... If this equipment does cause harmful interference to radio or televisionreception, ... The LCD panel used in this television contains millions of thin film transistors that ... 15. or cable system during a lightning storm or when it is left unattended and ..... There are four options lised under the Closed Caption menu.
    COBY TFTV1525 INSTRUCTION MANUAL Pdf Download.
    www.manualslib.com > ... > Coby Manuals > Flat Panel TV > TFTV1525
    COBY Electronics TFT LCD Widescreen Television Instruction Manual. ... Cobyelectronics 15" widescreen lcd hdtv/monitor specification sheet (1 page) ... Operation is subject to the following two conditions: • This device may not cause .... Direction &OK While working with the system menu, press the direction buttons to ..
Jan 13, 2016 | Coby TFTV1525 15 in. LCD TV
Lightning storm
More than likely the module/chip got fried by a voltage/lightning spike.
It's cheaper to replace small appliances than to repair them.
Suggest buy a new one.
Nov 02, 2017 | Coffee Makers & Espresso Machines
Does Panasonic TX-37LX80M 32" Widescreen LCD Multi-System HDTV with HDMI come with a safety gear which blocks the lightning from striking the television?
Please understand, that a lightning will have trillions of volts, when it hit the earth. Do you thing any material or circuit made by a human being can withstand it? All are only mere saying. Not the truth.
Jul 12, 2013 | Televison & Video
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
We were just given a pl26 tv, by can not find where to plug the cable connector into the tv, help
this information may help
32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 ...32" Protron PLTV-32 720p Widescreen LCD HD-Ready TV - 16:9 800:1 6ms ... Front Panel Controls: IR sensor ; LED; Top Panel ... Model: PLTV-32; Product Requirements: HDTV receiver
May 05, 2012 | Protron PLTV-26 26 in. HD-Ready LCD...
Ref: 26" 26PF5521D model. Following
I'm afraid the electronics have been 'spiked' by the lightning. It may have affected more than one module There is little you can do other than having it looked at by a professional, however you may be able to claim on your insurance?
Regards
Feb 03, 2011 | Philips 26PF5521D 26 in. HD-Ready LCD...
Lamp signal light is blinking after a thunder storm, no sound or picture
The projection lamp is dead,some how got shorted in the thunder storm.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Aug 03, 2010 | JVC HD-52G787 52" Projection Television
I have a HPp2081 and last night we had a severe thunder storm. My computer went off and when it came back on it had a White block with OSD Lockout on it. I don't know how to fix this or get it off my...
Turn the monitor off.
Unplug it from the AC power.
Reconnect it, turn it on, and see if it returns to "normal".
Do you have house-insurance that covers electrical damage from lightning/thunder storms?
Jun 23, 2010 | Computers & Internet
Lightning Storm/Affinity Washer
During a lightning storm, a lightning strike could have induced a high voltage surge in your incoming power lines. Left unprotected from these power surges, the weakest link ( normally low voltage electronic controls) are the most susceptable. Just because you had power available at the wall receptacle after a storm doesn't mean that your washer control system wasn't exposed to one of these surges and got damaged. On the contrary, it is extremely likely that the washer took a 'hit' and was damaged.Other devices plugged into the same receptacle may have survived that hit because electricity travels the path of least resistance.. In this case.. that path may have been thru your washer.. My point being is that your washer could have sustained a power surge and was damaged so don't rule that out. Of course, that surge could have taken an internal fuse or other component out too..
Jul 17, 2008 | Frigidaire Affinity ATF7000E Front Load...
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
