Can,t connect to second computer getting a message network cable unplug.
    Problem Solver:
  • 5 Answers
Is your computer connected to a network using a Local Area Network connection??
let me provide some solutions for windows XP users.....
first of check the LAN wire connected between two systems..
try to avoid any loose contacts. make sure the wire and jack are in good condition.. if the jack is loose please replace the wire or else tighten it using a crimping tool... also make sure that second system has a proper network device(ethernet card/Network Interface Card) and the corresponding drivers installed. if everything is correct bring both system into the same work group. then try to connect the second system
Posted on Sep 14, 2008
After having unplugged my computer from router for a period of time when I hooked it back up I get no signal msg on monitor how can I fix it
Troubleshooting Network Problems on the Dell V525w and ...
www.dell.com/support/article/us/en/04/SLN129390?c...l...
DellMay 13, 2015 - My Account .... Back to Top ... The printer, the computer, and the access point (wireless router) are ... Try unplugging other devices that may cause a conflict with the USB ports. ... with only the VPN and no other network at the sametime. ... message during installation indicating that the printer does not have ...
Connection Keeps Dropping Off - NICs - Components - Tom's Hardware
www.tomshardware.com > Forum > Components
Tom's Hardware Guide
Mar 8, 2010 - 30 posts - ‎23 authors
I will sometimes lose my internet connection within windows. ... When I hook up the cable modem directly to the host PC everythinh ... My desktop has a linksys wireless NIC and I have no problems with it ... Comcast says when the cable box loses it'ssignal, the router can't get good communication back with ...
No Signal Message On Monitor And PC Gets Restart?
forumarray.com/no-signal-message-on-monitor-and-pc-gets-restart-1421...
Nov 18, 2015 - started recently, when I boot my PC, the screen shows message: no signal and screen stays dark. ... then to get the signal back again, i must restart mysystem. then after boot up, i get ... Dell :: Having Trouble With Display On External Monitor .... laptop screen working until I unplug the 2nd monitor and restart my computer. What Is A Signal Cable On The Computer - Logo
Jan 17, 2016
BSOD When Unplugging Ethernet Cable - Logo
Nov 19, 2015
Monitor Doesn't Get Signal From Computer?
Nov 13, 2015
Cable Unplugged Network - Logo
Mar 22, 2013
More results from forumarray.com
Jan 27, 2016 | Dell Computers & Internet
Its always show at the the monitor the " A network cable is unplugged".
If you are connecting to the Internet using a wireless connection and your LAN card in the computer does not have a LAN cable connecting it to a hub or router then you will get a message "A network cable is unplugged".
If you don't use a wireless connection and you only connect to the your network/Internet then the problem is either the LAN cable has come loose in the computer's LAN card or at the router or the LAN cable is faulty.
Nov 17, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Message says a network cable is unplugged... but everything is hooked up properly. My wireless is working fine. I switched towers but used all the same parts out of the old one. And now Im getting that...
network cable is unplugged this message only appears when you are not connected through cable and that`s what you are doing.for your information it`s very normal which you`ll see in every computer.
Jul 15, 2009 | Westell Wirespeed VersaLink...
I have a cisco router linksys. I connect internet cable to it in ethernet port. Neither by wire not by wireless I can connect my laptop. The connection comes as only local
If you can plug the cable that you have ran into your router into your computer directly and it works, then you can plug the router back in. Then connect the computer to the router via cable and unplug the router for about 15 seconds and plug it back in. If you connect the computer by cable directly and it doesn't work, then try unplugging your router for about 15 seconds and then plugging it in. I have found many networking items that need to be reset whenever a network cable is plugged in when the device is powered on.
Jun 08, 2009 | Cisco Catalyst 2908 (WS-C2908-XL)...
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
I look forward to hearing from you.
Jan 04, 2009 | Televison & Video
How do i have a usb port run a high speed device
The USB port in your computer is not the new high-speed USB 2.0 version, and when you plug a USB 2.0 device in you will get that message. Most USB devices will still work but not give best performance. Just close the message window.
The network cable unplugged message can be disabled through the network settings. Normally Windows is set to display that message when there is no network cable connected. You can just ignore the message.
Dec 09, 2008 | Compaq Presario 700 470024-192 Notebook
NIC blinks on then off for longer run lines
You need to update the firmware of the router then hard reset it.
Download the router's firmware at www.linksys.com/download
After updating the firmware, you need to hard reset the router.
Press the reset button at the back of the router for 30 seconds then unplug the power for 30 secs then plug it back in. That should fix it.
Jul 01, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My laptop cannot locate my network
I can not open my labtop on my wireless, it ask me for my password, I give it and it tells me it is the wrong one. I have 2 computers on it with know problems..
Feb 25, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
Network adapter is working but still not getting good connection
Make sure the light on your cable modem that represents your connection to the computer (it might be marked LAN, Ethernet, or PC) is lit up and isn't flashing. The light will tell you if your network card is properly connected to the cable modem.
If the light isn't on, make sure you've connected the wire to the right port on the cable modem, and try restarting the cable modem by unplugging it, wait 30 seconds, and plug it back in.
If it still doesn't work after that, contact your Internet provider. Their technical support department can help you get it set up.
Dec 06, 2007 | HP Broadcom NetXtreme Network Adapter
Ibm think pad t30
To my knowledge, your laptop (IBM ThinkPad X30 2672) does not have any built-in WiFi. It's modes of connection are IrDA, modem, Ethernet, USP, Firewire aside from the regular serial & parallel. This would indicate that if you are wireless you either have a USB dongle or PCMCIA card. Please post back with your WiFi brand/model and your Operating System. Further, please post back likewise your WiFi AP/Router brand/model.
The message "a network cable is unplugged" pertains to the absence of a lan cable connected to your Ethernet port.
Good luck, kind regards and will await your second post.
Nov 16, 2007 | IBM ThinkPad X30 2672 Notebook
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
