Question about Sylvania 6620LG 20 in. EDTV-Ready LCD Television
Shut down while watching (no sound or picture)
TV shut down while watching, first heard faint "click" (ie: relay probably dropping out) and set went out completely. Manual on-off does nothing. Later when plugged unit in again heard "click" then 2-3 seconds later it clicked again. Concluded that a relay activated on power-up then dropped out.
Am a EE so took back off set: fuse OK along with all diodes and power resistor. suspect problem is in one of the low voltage power supplies as there is only 3 vdc at (12vdc) relay coil. I could order repair manual but may not be worth effort as most surface mount devices are not "home replaceable".
TV cost just under $300 and cost to have repaired may not be worth it.
Your advice requested.
Regards, Steve
  • 2336 Answers
SOURCE: flat panel tv blows fuses
If the same fuse blows again as soon as you plug it the LCD to the AC outlet, It means that a transistor(s), capacitor(s) or diode(s) are shorted.
I can repair the power supply for you. Let me know if you need further assistance.
Posted on Nov 10, 2008
ginko
  • 19396 Answers
SOURCE: No power up
You need a reay, RJP3053
Buy from RELAY STD DPDT for $ 2.79
Posted on Dec 23, 2008
dsacco86
  • 1077 Answers
SOURCE: New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Posted on Jun 01, 2009
dsacco86
  • 1077 Answers
SOURCE: SYLVANIA 42 INCH 6842PEM DOES NOT TURN ON
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 28, 2009
  • 8457 Answers
SOURCE: this tv shuts down and goes into protect when
power board ic converter it dead.
Need new power board can get in the web.and replace it or hire tv. repair man part labor $575
Posted on Aug 12, 2009
While I was watching my Emerson TV I heard a loud click and the screen went black and audio went off. When I press tv button on cable remote the tv button glows red, and nothing happens on the tv.
Hi the power supply might have shut down through overheating turn the power of at the wall socket & wait for a short time before trying again the TV might reset itself if this doesn't work its probably shut down from a faulty component. good luck
Oct 23, 2016 | Emerson Televison & Video
Tv just turn off during use.
You may be having problems with your overcurrent shutdown circuit. This circuit shuts down you high voltage power supply due to components drawing excessive current, If you do not have electronics experience I would suggest taking the set to a repair shop.
Sep 24, 2007 | Panasonic PT-52LCX65 44" HDTV
I have the Toshiba Theaterview. Was watching it when I heard a sound and the screen went black. The Red Light will come on and glow steady and you hear it click when you try to turn it on or off but...
Something is causing the TV shut down or go in to 'protect' mode.
It is unusual to actually hear a component inside the TV go bad, but you obviously did. Probably in the main power supply or something that normally uses a higher voltage in the TV since you heard it..
Jan 25, 2015 | Toshiba Televison & Video
I was watching my 50'' plasma and when i heard a click and the set went dark. When I turn it on I hear a double ''click'' and the screen stays dark.
Your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The sound is it starting up, shutting down, over and over. You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Feb 03, 2010 | Vizio VP50 10A 50 in. Plasma TV
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
HL-R4266W shuts down and a faint clicking sound can be heard
I believe I read somewhere that when you open the back cover over the lamp, there is a special little black switch that needs to be in the up position when you put the cover back on, or the TV can shut itself off randomly.
Aug 16, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
Apr 11, 2009 | Dynex DX-LCD37 TV
Sony Trinitron KV-27V25 won't turn on
Its power supply issue and you need service manual to repair power supply on component level.
Get service manual from Manual Zone with little fee and test power out.
KV-27V25 is 1996 model and very much old.
Dec 07, 2008 | Sony Televison & Video
Tv popped and shut off
Burnt small 2KV capacitor near flyback xformer....original is
221K....I use 271K / 2KV ...Possible burnt 1K 1/2 watt resistor
and shorted zener diode ....ECG 519..................T.
Dec 08, 2007 | Zenith B27A11Z 27" TV
No Power
Your set is going into high voltage shut down. Might have been the high voltage transformer that has gone bad.
Mar 09, 2007 | Hitachi 60UX58B 60" Rear Projection...
Sylvania 6620LG 20 in. EDTV-Ready LCD Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
