Marantz PV5580W (aka Philips 5580) IC Analog problem? There is no red...
I have a Marantz PV5580 (Philips 5580) tv. It is also known as Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}"Philips 55PP9701, ML559501, 9P5534C",OR "Magnavox 55P9271". Let me first describe the problem. When the analog inputs (coax, dvd component in, and rca) are used there is no red. Red flashes intermittently, but not very often. The HD input works fine. It appears to be on a seperate circuit board. Philips has been no help, and I do not have any local repairmen.
After doing TONS of research, it appears to be an IC issue. I am looking for anyone who knows what parts I would need to purchase to fix this problem. My father is an electrical engineer and can solder almost anything. I would love any help or assistance with this problem! Thanks!
  • LostObserver Sep 14, 2008
    For some reason the original format of my question is all screwy. Here is the question againg:
    I have a Marantz PV5580 (Philips 5580) tv. It is also known as "Philips
    repairmen.
I have the exact same tv with the exact same problem. Did you figure out how to fix it?
Posted on Sep 25, 2009
How do i connect marantz rs2252. To tv
Do you have an audio out or headphone jack on the TV? If not you'll need a digital TV tuner converter box that does. If you remember, these are the "digital conversion" boxes the government provided when the USA switched from analog to digital TV. They sell for $50 - $60, have a input for TV system (antenna, cable, etc) and analog outputs that will connect to your Marantz via the "Aux" input. Purchase shielded "RCA male to RCA male" connection cables at Radio Shack, connect "Audio Out" from converter box to "Aux In" on Marantz and you're done.
Mar 28, 2015 | Marantz Audio Players & Recorders
Marantz nr1402 how to connect turntable
Connect turntable out to phono preamp In
Conect Phono preamp out to your Marantz NR1402 vacant analog input.
On your TV , if audio out is available connect it also on the Marantz
vacant analog input 2
Aug 01, 2012 | Marantz Nr1402 Av Receiver
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
Do have an idiots guide as to how to wire up the SR-4200 to a TV
I will interperate this as:
"So you want to play sound through your Marantz SR-4200?"
You need to clarify what sort of system setup you have, however i will put down a few ways to wire this up to your TV.
If you have a Set-top-box that gets the TV Channels, that is where the sound comes from. If you have a TV that plugs straight into the wall, you will have to get the sound from the TV. Grab a RCA Stereo cable - (White and Red heads, if you don't know what they look like, Google it).
If you are unclear about this, i have tried to make a diagram down the bottom to explain how this is to work. What you will do is Take the sound from the Set-Top-Box or TV and reroute it into your fantastic Marantz SR-4200.
1. Plug Red Plug into the the Red Slot, and White into the White on the back of your set-top-box or TV Out (if you get it around the wrong way, the speakers will be reversed.)
2. Plug the other end of the cable into the back of your Marantz SR-4200 in the TAPE input or VHS input as they are analog signal inputs. Turn on Marantz SR-4200 and turn it onto Tape or Vhs (depending on where you plugged it in).
[Set-Top-Box or TV out] >-------> into >------> [Marantz SR-4200]
If you still don't get it, then try searching You-Tube for a guide "Plug Tv into Stereo". I myself couldn't turn up anything useful
Mar 09, 2010 | Marantz SR-4200 Receiver
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
Distortion on left channel of analog output
Based upon your description, the most likely caue is the D-A converter chip inside the marantz. This is a relatively common failure. Replacing the IC should resolve the problem.
Dan
May 20, 2009 | Marantz DV8300 DVD Player
Marantz PV-5580W Color Problem, Missing Red?
I have the same model however my screen is red w/ green lines. Did you find a fix to the problem?
Jun 30, 2008 | Marantz PV-5580W 55 in. Rear Projection...
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Oct 15, 2007 | Marantz SR-5200 Receiver
Service manuals
You can search this database for the service info you seek about your tv here:
http://www.samswebsite.com/photofacts.html
Most service manuals with schematics cost about $27.95 for the PDF version of it, otherwise the paper version is about $15.00 more for handling and shipping.
You will need the chassis number of the unit in question in order to search for it. I hope this helps!
Good Luck!
Rich Lilja
Apr 30, 2007 | Philips ML55-9501 55 in. Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
