Cobra 29 LTD CB Radio Logo
Posted on Sep 12, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can hear everyone talk to me but i cant transmit to them,they can hear me key up but no voice to them.i have checked all connections and grounds,still the same.
Laron
Level 2:
Novelist:
  • Expert 146 Answers
  • Posted on Sep 17, 2011
 Laron
Expert
Level 2:
Novelist:
Answers
146
Questions
0
Helped
46105
Points
197
Mic may have audio wire broken in cord at mic plug wire solder connection.
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
notice the numbers on the black plug after you pull it out of the radio.
1helpful
Cobra 29lx Bluetooth max mod's available
Hey there! When it comes to the Cobra 29LX Bluetooth, there are a few mod options available to enhance its capabilities. However, it's important to note that modifying your radio may void any warranties or legal certifications it has. So proceed with caution and at your own risk.
Now, let's talk about adding a tune talk back voice to your Cobra 29LX Bluetooth. The tune talk back feature allows you to hear your own voice through the radio's speaker while you're transmitting. This can be handy for checking your audio quality or making adjustments to your voice modulation.
To install tune talk back, you'll need to follow a few steps. First, you'll need to open up your radio's casing and locate the talk back circuit. It's typically a small board with components related to the talk back function.
Next, you'll need to identify the audio input and output points on the circuit. These are the spots where you'll connect the necessary wires.
Once you've identified the right points, you'll need to solder a wire from the audio output of the radio's microphone circuit to the audio input of the talk back circuit. Make sure to be careful and precise with your soldering to avoid any damage.
After the connections are made, you can reassemble the radio and give it a test. You should now be able to hear your own voice through the speaker when you transmit over the radio.
Modifying your radio can be a bit complex, and it's crucial to have a good understanding of electronics and soldering techniques. If you're not confident in your skills, it's always a good idea to seek assistance from a professional or someone experienced in radio modifications.
I hope this explanation helps, and if you have any more questions, feel free to ask!
My voice does not transmit through the earpiece
Sounds like you have a problem with your microphone.
Please contact us.
Mark
Motorola Support
CONTACT US
I have a tk -250 and I can hear everyone talking but when I try to respond to them all it does is beep
Are you sure the people you hear talking are in the band limits of the radio. Generally, when they beep on transmit it's because you're trying to transmit out of band. If the stations you're hearing are near the band edge it's possible you have the "offset" wrong and when you hit the PTT, the shift (offset) in the wrong direction is taking the radio out of band.
2answers
The problem is wen im having a coversation onlyn wid a person i cant hear dem proper cpz der voice keeps cutting on msn....n wen i try skype dey cant hear me but i cant hear dem coz der voices keeps...
Do have an issue with your audio? Can you play music without any problems? If you are only having problem with skype/msn then you just need a faster internet connection.
Thanks for using Fixya!
2answers
I can hear people when they all me but they cant hear me how do i turn the mute off
The phone is not on mute, it has a bad mic. You would need to replace the mic in order for the other party to hear you.
www.usedcellphoneshop.com
Voice recognition on motorola t5500
That means that it will Transmit, like pressing the "Talk" button, BUT ONLY when it hears the "Voice" it was "Trained" on. So this is so No-one else could use this unit. With this method. You "Identify" yourself, and after that every-time you speak, the Transmitter is keyed, and the channel is opened and the voice sent, when you stop talking,it goes back to receive, again. Some are less sophisticated, in that they are really a "Sound Switch" and when the unit "Hears" a "Voice" it, switches OFF receive, and ON the transmitter, and Transmits the audio out.
I cant hear the other person in voice chat
since you are facing problem with all the IM's. check the connection speed. sometimes even EDGE is not enough for voice chat. try it with a better bandwidth connection.
When I Press the mic to talk, others hear me key down, but no sound is transmitted
Hello lummox30,
Check you mic first to see if it is indeed working. Then if it is the below advice is applicable.
It sounds as if your TX audio amplifiers might be malfunctioning or the TCXO might be bad. If you have a background in Electronics I would suggest that you open up the unit and using a dummy load on the antenna check the two TX audio amps to see if when you key the mic and speak into it the amplifiers are amplifying your voice and sending it to the modulator. If the problem is not amps or the filters in between the amps, the modulator and the VCO buffer are suspect. If the TCXO is being modulated I would check the PPL IC and the Drive amp to see if the modulated signal is getting through. The last two checks I would perform are on the final amp and the TX switch prior to the antenna jack.
If you do not have a background in electronics, still check your mic, but the rest of the above advice can be done by a qualified Radio Technician.
I hope this helps,
Thank you,
Shuttle83
Staying keyed up after button release
I have never seen this problem before, check if the VOX is activated, this could cause to transmit the radio, but the voice must be transmited. check if the Accesory connector is not dirty, clogged or damaged
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
