Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Where is the water filter located
Need to know where water filter is located.
  • kalapurayil Nov 01, 2008
    could not locate where the water filter is located
  • 104 Answers
Open the fridge door and look on the top right side
Posted on Sep 14, 2008
I have a GD22DQ model side by side whirlpool gold refrigerator. we have looked through the manual and we cannot find were to put the water filter. the manual shows a dial at the bottom of the fridge but...
Hello Dollar1392,
I understand that you can not locate the water filter for your unit. If you have a water filter in your unit it will be located in one of two locations at the bottom of the unit in the grille or in the top of the refrigerator section on the right side in the rear corner. If the filter is not located at one of these locations then there is no filter on your unit. You will need to put an in-line filter in your water supply line.
Thank you for choosing FixYa.com if you have any further questions please post back to the thread.
Justin
Apr 23, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
I need to know how to clean filter. Lost book
follow the below instructions:
Turn off the dehumidifier machine and unplug it from the wall.
Lift the water bucket up and out of the dehumidifier.
Locate the filter located under the compartment that houses the water bucket. Lift the filter straight up and out of the dehumidifier.
Vacuum as much of the visible dirt and debris as possible.
Fill a sink half full with water. Place the filter in the water and allow it to soak for one to two minutes.
Wipe both sides of the filter with a wet sponge to remove any remaining dirt and debris. Rinse the filter with clean water.
Wipe the filter with a dry cloth to remove excess moisture. Allow it to air dry for approximately 30 minutes before inserting it back into the dehumidifier.
Good luck.
Aug 11, 2010 | Frigidaire Dehumidifiers
Not getting enough water flow into the dishwasher, suspect that a filter is clogged due to recent work on the waterline in the kitchen sink. Need to know where the filter might be located (on the...
You didn't specify a brand but most dishwashers don't have a water "filter." They may have an inlet screen at the water valve, which is typically located under the dishwasher. Generally, the lower front panel will have to be removed and you should then see the water lined connection to the unit. The front cover may have insulation behind it for sound deadening.
Be sure to turn off the water and power to the dishwasher working on the appliance.
Jan 01, 2010 | Dishwashers
Location ofwater filter(s) whirlpool modeled22dq
Hi, The filter is located behind the kickplate. You can see the handle for the filter in the kick plate. I believe you turn the filter handle Counter clock wise to remove it. It will tke a little bit of force. Yes this filters the water in the door.
Let me know If I canassist you further. Thanks
Vic
May 17, 2009 | Whirlpool ED2FHEXN Side by Side...
Location of refrigerator water filter
The filter should be a canister somewhere in the line from your sink to the refrigerator. If there is no canister visib;le there then obviously they never installed a filter in the first place. I hope this helps. Don't forget to rate my answer. thanks.
Feb 21, 2009 | Refrigerators
Water not coming out
Without knowing the model # filter is usually located on bottom of fridge in grill. When you depress the lever listen for the water valve in back of fridge to click on if not you may need a new water valve. What is the age and model # of fridge?
Nov 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water in the fuel
Evidently you got water in the sensor connecter. The fuel filter is located on the right side as viewed from the front of the engine about even with cyl 4. unplug the sensor in the bottom of the filter and blow it and the connecter out with compressed air and plug back in, this should take care of your problem. Since you know know where this filter is it needs to be drained and/or replaced from time to time when this light comes on also.
Aug 03, 2008 | 1994 Dodge Ram 3500
Filter
Water filters for most refrigeration cabinets are located externally to the cabinet as they are quite large. If you have one you would know. If you dont have one fit one as they make a large difference. Once fitted make sure you run the water through. Hope this helps.
Aug 17, 2007 | KitchenAid KSRS25CNBT / KSRS25CNLK /...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
75 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
