Remote for Magnavox MRD 200
Hey, I see you had problems with your MRD 200 unit recently. My remote recently broke and I'm trying my hardest to find a replacement. Are you still using your unit?
  • Carlitobriga Dec 18, 2008
    I broke the remote. I need a replacement. or maybe program another remote to it...
  • hodge413 May 11, 2010
    I am trying to use a Sony RM-V210 Remote Commander and so far all I can get it to do is Turn my Mrd200 Off that's it This Mrd 200 is turning into a pain in the A__. I got the thing(mrd200) to play music play some movies,but now I lost the sound. I am trying to run this on the console itself. The strangest thing is it will not play any DVD's that have any kind of Copy protecting of which most all of the Movies now are all copy Protected. All I want to do is play Movies in Surround Sound or any sound for that fact. I really NEED to find a remote. I know there is a replacement Remote A PM6255,but I can't find one of them either. So if anyone has any Idea's on how to can at least get my sound back or where I can find a Remote I would be very greatful,because this MRD200 is driving me NUTS. Thanks
    Problem Solver:
  • 4 Answers
Solution NO I need a Remote that will let me use this thing. I can play it,but without the remote you can't adjust the Surround sound Speakers. Can't adjust anything really. If you push the wrong button on the unit itself It will go into mute mode then have to wait until it decides to play again. PLEASE somebody out there must have some idea on where to get one(remote) or replacement. As for the Company that made this system DONT even go there. They just don't care Really I will never bye anything from that Company again. What kind of Company dose not back there Product. That's why there on the Bottom as far as Electronics go. Thanks any Help on this will be appreciated.
Posted on Apr 17, 2010
How do i program my hamton bay universal remote to wor with my magnavox vcr/dvd recorder combo unit
Magnavox VCR codes are 007, 011, 028, 032, 059
Magnavox DVD code is listed as 001 only.
Manually turn on the device. Press and hold the SET button then press and release the VCR button, then release the SET button. Enter a three digit code then press power. If it does not turn off the device, try the next one.
You might also try the 'code search' if none of the above codes work. Press and hold SET then VCR and release both. Then Press and release the SET button again. The indicator light should begin blinking. Press and release the POWER button until your device turns off. You may have to go through up to 200 different codes until it turns off. Once the device does turn off, press the VCR button again to store the code.
Jun 19, 2009 | Universal Remote Control Hampton Bay...
MWD2205 remote stopped working for DVD functions
not sure but it sounds like you need to push the dvd button itself before dvd functions will work-it's to the left of the pause button. same thing happened to me and when i try that it works. remote seems to default to vcr i guess ....
Mar 23, 2009 | Philips MWD2205 DVD Player/VCR
I have a rca remote (rcu404) my tv is a magnavox. I can not find my book so I need help finding the correct code to program the remote to the tv. Thanks I do not have the code book for my remote control....
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jan 14, 2009 | RCA RCU404 Remote Control
Lost remote mrd 310
most universals will use this method.
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 29, 2008 | Philips Magnavox Learning Universal Remote
Magnavox 55
Sounds to me like you need a new control panel board which should run you about $150-$200 max! might be semi burnt out like mine was and that is what i had to pay not sure if this helps but hey ya never know :)
Sep 08, 2008 | Philips Magnavox 55P9271 55" Rear...
No sound form my magnavox mrd-200
As long as the colored connections are in the correct holes (red with red and so on) then you should have sound if not then the built in amplifier is shot, it is probably better if you get a new system or contact Magnavox for a exchange price on out of warranty units which they have
Aug 16, 2008 | Philips 0603 magnavox mrd200 System
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Jumbo universal remote
I found that on the back of the 2205 it said that the unit was made by Funai. I looked in the Innovage book and found that the codes for Funai DVD are 231 and 233. 233 worked on mine. Good luck.
Jan 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Finding a universal remote for this tv!!!
quisiera conocer el mando a distancia original
Dec 19, 2007 | Philips Magnavox 27MS343S 27" TV
287 people viewed this question
 Grubhead
Grubhead
