Question about GE Microwave Ovens
Have Advantium Oven 120,Model #SCB1001MSS01.. Oven works, but there is a double row of Green blocks on the display area, Cannot set time or clock.
  • sjlinx Sep 14, 2008
    I have the same problem---we did have small power surge this morning...tried resetting the circuit breaker with no change...can i try anything else??
  • William Miller
    William Miller May 11, 2010
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour.
    Then let us know if the hard reset does not fix it.
    Can you post a good photo of what the display shows?
5 Suggested Answers
MicrowaveSvc
  • 9042 Answers
SOURCE: GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Posted on Oct 05, 2007
MicrowaveSvc
  • 9042 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
MicrowaveSvc
  • 9042 Answers
SOURCE: I have a GE profile
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Posted on Jul 11, 2008
MicrowaveSvc
  • 9042 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
MicrowaveSvc
  • 9042 Answers
SOURCE: Kenmore Elite Advantium 120, model # 363.63693301,
You probably just have a bad primary interlock (upper door switch) or its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader.
For more on door switches & mounts, see:
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
But if you need any cosmetic parts,
enter your full model number at the Sears parts site.
Posted on Jul 13, 2009
Our Advantium 120 oven (model # SCA1001KSS 02, Manufactured June 2008)is not working. Began w/ time not coming on when cooking and just a little green microwave light shows while cooking.
Typical of a control microchip failure caused by a power surge. With a microwave as old as yours, it is safest to simply replace the entire oven rather than attempt to fix it, as older magnetrons are likely to fail.
May 05, 2015 | GE Profile Advantium 120 Above-the-Cooktop...
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
I have a GE Advantium 120 and the power keeps failing when I try to use it. Then the light and time will come back up. Keeps happening. What should I do?
It depends on the exact failure. I'd need a more detailed description of how long it runs and whether you need to set the clock
The two likeliest possibilities are a noisy magnetron, or a magnetron that is overheating because it is failing, an air vent or filter is blocked, or the internal cooling fan is not working.
For details on a "noisy" magnetron and how to diagnose it, see
this FixYa solution even though your model number is different.
The full service manual for your model (with installation & removal info) is here.
You can find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Apr 27, 2011 | GE Advantium 120 Convection/Microwave Oven
Hi, my problem is with my GE advantium speedcook microwave oven. When using 'speedcook' feature, the oven starts, then there is sparking inside the circuit board area, followed by a loud POP, and this...
  • Select the "Options" menu and adjust the clock display settings if the display is blank. Set the clock if the oven won't start. The clock must be set for the oven to work properly, as oven programming is dependent on the clock.
  • Close the door tightly if the oven won't start. The oven won't start if the door isn't closed. You can identify from the lights whether the oven failing to start is related to the door or to the power supply. If the control panel is illuminated and interior lights are on when you open the oven door, you can be sure the oven is receiving power and any starting problems are due to the door not being closed tightly.
  • Press and hold the "Clear/Off" button if the oven performs strangely. Be sure to hold it for a few seconds. This will reset the GE Advantium.
    But as you mentioned that there is /was a loud noise this is a indication of the unit make any usual noise (groaning, gurgling, etc.?) or was / is it either louder or quieter than normal?It may be as simple as the top door switch or its mount or it may be a bad magnetron or shorted diode.
    For manual of the oven.please click the link below:--
  • http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40577-1.pdf
  • Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • Aug 12, 2010 | GE Advantium 120 Convection/Microwave Oven
    Display on my ge Advantium 120 convection/microwave has gone blank. Just a blinking -
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes and try it again.
    If it's still not working, it may have a failed keypad or a problem with the controller.
    The full service / installation manual is here.
    We repair these all the time, and would be happy to help you with more info at no charge. Feel free to contact us.
    Jun 26, 2010 | GE Advantium 120 Convection/Microwave Oven
    The display on my GE Advantium microwave oven shows "LOCKED". I tried holding the clear/off button but it won't clear. the microwave is unusable at this point
    If that doesn't work, leave it unplugged for about 5 minutes.
    If yours is an Advantium, one of these owner's manuals will help you set the clock if you need help:
    http://www.microwavedisplay.com/sca1001kss_om.pdf
    http://www.microwavedisplay.com/sca2000_sca2001_om.pdf
    If you still need help, note that FixYa's Web site is currently not notifying us Experts when replies to our Clarification Requests are posted, so please post a new help request, but be sure to include your full model number from the tag in or on the unit.
    Apr 24, 2010 | GE Advantium 120 Convection/Microwave Oven
    It won't shut off and the control console shows just green blocks
    If you still have trouble, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and detailed your symptoms.
    Dec 11, 2009 | GE Advantium 120 Convection/Microwave Oven
    Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
    Microwave Ovens Logo
    234 people viewed this question
    Top GE Microwave Ovens Experts
    William Miller
    William Miller
    D. E. Hev
     Larry
    Larry
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
