Hi ldysmn72...
Keep this in mind, you will need this info later.
Start your computer in the bios mode
To start in bios mode:
Shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
You will do a repair to the operating system
1...Repairing the Operating System...
A...You will have to have the Operating Dics that came with the computer.
Note...If you do not have the disks that came with your computer or the ones you should have made when you first got your computer...then you will have to go to the manufacture's webpage and see if they have a recovery disk available for your computer, if they do not a recovery disks available then you can also try ebay to locate the recovery disks.
The original disks will have your product key number that came with the computer, you can also find it on the tower, or under the bottom of your laptop, or maybe the piece of paper that the CD orginally came in may have the number on it.
You can also download a small program and it will tell you your product key number.
Go to the following webpage to download your FREE key finder.
http://www.magicaljellybean.com/keyfinder/
B...You will now insert the disc into the CD/DVD player
C...Restart the computer
D...When the window opens that tells you to press "Any" key, you will press any key you want to press.
E...If you do not receive a message that says "press any key to boot from CD", then then the computer is not ready to boot from a cd.
To correct this problem you will have to go into your computer's Bios and change the computer to boot from a CD.
To get into the Bios, shut the computer off,restart, while the computer is starting up keep tapping F1 as the computer is starting up.
When you are in the Bios, select to boot by CD by moving the cursor with the direction arrows on the keyboard.
Once you have selected to boot by cd the exit and restart the computer...the disc is already in the cd/dvd player.
Your system will then boot from the cd.
F...After a minute or less it should ask you if you want to Quit Repair, or Continue.
You will select Repair this time, but you may have to come back here and select Install if the repair does not work.
It will ok the agreement document if it asks you too.
Tap F8 on your keyboard to pass it when ready.
It will ask you if you want to Install, Repair, Delete Partition, or Quit.
Select Repair
Inside the box there will be one or two partitions.
Choose the largest partition.
After you have chosen the largest partition, you will then press the "r" key to start the repair
After the repair is complete, then you will need to restart your computer.
G...Computer Restart
After the repair is complete, shut the computer down (the computer will shut down a few times during the installation of the operating system
that is normal).
Then restart your computer, when the computer restarts it will have a box to put your product key...put the product key in the box and click.
The computer should start up and run as if it was a new computer.
You do not need to re-register
You can now remove the disc.
Please take time to rate me thumbs up
Insert the USB flash drive into one of the USB ports on your computer.
Momentarily a small prompt will appear saying the computer has detected a new removable device.
Insert the antivirus software installation CD into the disc drive of the computer to launch the installation wizard.
If you downloaded the program, double-click the downloaded file to launch the installation wizard.
Read through and accept the license agreement, then click "Browse" when shown the installation location.
A search window will appear on the screen. Choose the USB flash drive and click "OK."
Click "Next" for the installation name and select "Install." The antivirus program now will install onto the USB flash drive
hope this helps
To scan documents for editing and saving as PDF file, you will
need to install the Lexmark OCR scan software on your computer. The Lexmark
scan software (no downloadable version) is only available on the installation
disc that came with your printer. If you lost the disc, please contact Lexmark
Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
