Cant get the back panel off the washing machine
  • BelindaS Sep 14, 2008
    its a whirlpool
  • Dan Sharpe
    Dan Sharpe May 11, 2010
    Many washers do not have back panel access, what model of washer is it?
    Sniper:
  • 88 Answers
If it is a top loading washer the cabinet itself is actually removed from the back panel and base frame.
1. Remove two trim caps on either side of the control panel, they are just plastic, and clip in place, either remove by hand, or if they don't come right away you can pop them off with a flat blade screwdriver.
2. Remove two screws (now visible with trim removal) that secure the panel to the cabinet.
3. Panel should now be able to pull up and out, flip it back on it's hinges.
4. Disconnect the wire harness from the lid switch connector, this should be the only place (on most models) where wires connect from the control panel to the cabinet top.
5. Remove the two gold clips that secure the cabinet to the rear panel of washer, they snap into the cabinet, and should pop out easily with a flat screwdriver, this can be difficult to figure out which way to go with the screwdriver, the best I can describe it would be to slide the blade of the screwdriver into the front of the clip (about 2 inches below the cabinet top) and then press the screwdriver back over the top of the clip for leverage. It should pop right out.
6. With the clips removed, you should now be able to simply tip the cabinet towards yourself and pull it right off of the frame. The washers "guts" should all be accessible now.
Hope that helps.
Posted on Sep 15, 2008
How do you get the panel back onto the back of the machine with the two gold clips? We can't seem to get the clips in place.
Posted on Nov 25, 2008
Cant get front panel off washer to check mcu unit as suggested.
There should be 3 t20 tork screws at bottom of kick panel. You could also take the whole back panel off to get to the motor control unit, it is located in the back lower rh corner.
Jan 26, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
Cant get top panel off
top panel is normally held by 2 or 3 screws on the back of the machine. the whole top will then slide back and can be lifted off
Feb 21, 2011 | Hotpoint Washing Machines
Kenmore 4563291 top loading washer quit in rinse cycle power to machine is good but total unit is dead - Cant figure how to get to timer circuits etc. Cant find parts manual or circuit diagram
unplug for 30 seconds then plug back in and advance timer around to start again. if still nothing take off the top back panel there should be a fuse
Apr 15, 2009 | Washing Machines
Dead in the water
THERE IS SCREWS ON THE BACK SIDE OF THE PANEL, REMOVE THE SCREWS AND PUSH FORWARD A LITTLE WHILE PULLING UP AND IT WILL LAY DOWN RIGHT ON TOP OF MACHINE, THAT IS WHERE I FOUND DIRECTIONS TO ALL THE PROBLEMS I HAVE BEEN HAVING
Mar 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
I cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
Jan 19, 2009 | Washing Machines
Cant open acces panel on washer
no panel to pull off ..remove 2 screws on rear of console ..pull console forward and roll back ..clip each corner remove and lean cabinet forward and lift off ..pressure switch hose is right rear and runs up back to console
Aug 28, 2008 | Whirlpool LSR7333 Top Load Washer
Washing machine door hinge
I cant find much on this unit. the back can be remove but will likely not help you .
remove the top access panel ,
remove the front control switch panel.
then you can remove the whole front door and all.
its really not that hard just be careful of the plastic items.
Feb 27, 2008 | Creda W100FW Front Load Washer
Washing machine wont drain
0872465395 Ire no charge
Dec 29, 2007 | Washing Machines
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
