Question about KitchenAid KAWS850LE Top Load Washer
Kitchenaid kaws750lq0 washing machine
I'm having problems with my model kaws750lq0 washing machine. What happens (and it doesn't happen with every wash) is once it gets to the Rinse cycle, it just sits there. I know a few minutes is normal, but it won't do anything until I do a Reset--(on water level knob) and move the water level up to a higher cycle, eg., from Small load up to Large load. Once it adds more water, it will then go through the Rinse cycle and spin as normal. Like I siad, it doesn't do this every time. Anyone have a similar problem or a fix? thanks, Mark
aborcass
  • 2651 Answers
SOURCE: KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
Posted on May 12, 2008
  • 409 Answers
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Posted on Sep 28, 2008
michiganfan9
  • 179 Answers
SOURCE: Our KitchenAid KAWS850LE1 Washing machine will not drain or spin
you need to replace the lid switch
Posted on Dec 23, 2008
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
SOURCE: Have a KitchenAid Prestige Top Load Washing
I had the same problem 1 month ago, its probably the motor coupling for the direct drive. Its a small rubber Ring + a plastik drive. Its easy to change and not expensive.
Here the link for the part
http://www.appliancepartspros.com/part_details.aspx?part_id=3963893
Posted on Jun 28, 2010
Kitchenaid motor
Come on we need a lot more info, what happened what model machine is it what problems are you having
Sep 24, 2013 | KitchenAid 32685 Mixer
Retarder ratchet slips during wash cycle
see the diagram attached. God bless you
Jul 21, 2013 | Haier XQJ50-31 Top Load Washer
Kitchenaid Styledmaster # 622784, The washer is leaking over the floor. All of the exterior hose connections seem to be OK.
Note : Make sure the water on the floor isn't the result ofa plugged floor drain. It happens!
Unplug the machine beforeperforming any repairs.
Thank for using fixya.
Jul 28, 2011 | KitchenAid Washing Machines
Washing machine doesn't fill with hot or clod water.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Jul 05, 2011 | Maytag Washing Machines
I can hear the motor running but the component doesn't turn. This happened when I was trying to make pasta.
There is a good chance that the Worm Gear Follower has been stripped
(i.e. all the teeth on the gear are damaged). Download a copy of the
Repair Part List from Kitchenaid.com for your particular model.
Depending on which model you have, it might be an absolute pain
to replace it without the proper knowledge and tools, especially the
Professional 6 Series.
Jun 16, 2011 | KitchenAid Food Mixers
The cold water drips in.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
heatman101
Mar 27, 2011 | KitchenAid KAWS700L Top Load Washer
Washer not taking in water in wash and rinse cycles in cold cycle
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 03, 2010 | KitchenAid KAWS850L Top Load Washer
Kaws750lq0-does not spin
Do you hear any noises coming from the machine when it is in a spin cycle?
yes----you probably need a new motor coupling, this unit does not have a belt, it has a coupling part number 285753A
NO--- then i would be willing to bet you lidswitch is bad, inspect it by listening for a clicking noise when you open and close the like. part number 8054980
Order parts here using these part numbers
http://lartoday.com/order_parts.htm
Levi Holiday
Lebarchrigen Appliance Repair
www.lartoday.com
Dec 09, 2009 | KitchenAid KAWS700L Top Load Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
KitchenAid KAWS850LE Top Load Washer Logo
237 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
