For basic cleaning, use a non-abrasive cleanser or detergent and water. Clean the oven frame, oven door outside of the gasket and the gap in the gasket. (Don't clean the gasket.) With a damp sponge (with detergent if needed), wipe up any spills in the oven. (Sugary or acidic spillovers could damage the porcelain.) Wipe up any grease that spilled in the oven. Wipe the control panel with a damp cloth then dry. Clean the oven door with detergent and water. Clean the window or glass with detergent and water or glass cleaner. Use care to keep the water from seeping behind the window.
Next if you want to do a self-cleaning cycle. Remove the oven racks, the broiler pan and any other pans or items that are in the oven. Close the oven door. Press the Clean pad and then press Autoset(0) button to get the length of time to run the cleaning cycle. Press 2 or 4 to shorten or lengthen the cleaning cycle. After 5 seconds the door will lock and the cleaning cycle will begin. The door will remain locked until after the oven cools down (at least an hour after the cycle ends). Wipe up any white ash after the oven door unlocks. If you want the cleaning cycle to be delayed, press the Stop pad within 5 seconds of setting the length of the cleaning cycle. Use the number pads to set the time that you want the oven to end the cleaning cycle. (Make sure that it is later in the day with sufficient time to run the cleaning cycle.)
Most Jenn-Air manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . The direct link to the manual for the JJW8530CAA is http://www.kitchenaid.ca/assets/pdfs/literature/JJW8527AAB.pdf .
I hope this helps.
