Control locked cant start washer did circut breakers, also unplugged it--nothing CONTROL LOCK, NOW THERE IS NO POWER AT ALL TO PANEL LOST BOOKI IN FLOOD HAVE NOTHING TO LOOK AT
I ended up unscrewing the top from the back, my husband pushed the drum slightly forward and I reached my hand down the side where the door locks and there is a plastic "thing" (almost like a tab) that you pull down and you can hear it click and my husband easily opened the door
Posted on Sep 16, 2008
The child lock on my LG front loader washer is now at about 5 minutes each load. How can I SUCCESSFULLY turn the thing off???
i think your issue is either the door lock itself or the control panel. i would start by unplugging the unit(or tripping the circuit breaker), then hold in the power button for about 10 secs--this resets many LG washer's electronics. then plug back in an see if that helps. i do not think your issue is the child lock feature, but rather the safety door lock feature. good luck.
Sep 17, 2016 | LG Washing Machines
Control locked
Press the end of cycle signal- button for 3 seconds and it should work..
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lid will not lock, Washer will not start: I press
There might be the issue of the lock as the control board tries to send signal to close the lock but it can not. This is common issue with the lock more than the control board.
Oct 11, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Control locked light is on
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. You also cannot unplug the washer to reset it. The Control Lock can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope you find this information helpful.
Apr 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
Control is locked
Have you tried pushing and holding the End of Cycle Signal" button in for 3 seconds? This button is used to lock and unlock the control panel as a safety feature to prevent small children from manipulating the controls. The instructions should be printed on the control panel near the button.
May 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Control locked
look on consoles for small lock emblem hold that button down 3-5 secs
Sep 01, 2008 | Whirlpool GHW9200L Front Load Washer
Control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
Jun 14, 2008 | Frigidaire GLTF2940ES Front Load Washer
Duet front load washer control locked--How do I undo??
Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom
of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
101 people viewed this question
Top Washing Machines Experts
