Question about Lexmark Office Equipment & Supplies
Lexmark 4049 laser printer. I know it is old. Keep getting 923 service fuser error message. Is it a major problem or should I just get a new printer
The fuser should run about $200 or so, plus the cost to install it. I wouldn't recomend getting a new printer unless you're otherwise generally unhappy with it; It would be worth it to replace the fuser.
Posted on Dec 11, 2008
I have an error message that says 924 service Fuser Error What does that mean?
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser yourself which costs around $350, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay.
Sep 03, 2010 | Lexmark T632 Laser Printer
Message on screen reads: 920.26 Service Fuser Error. I've tried switching it on/off, still won't work and none of the buttons will cause the error message to dissapear.
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T642, the manual states you should power off the printer and power it back on, which you did, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $350, so I think you would be better off getting a new printer unless you find a second hand one on Ebay.
Aug 22, 2010 | Lexmark T642 Laser Printer
Invalid engine code?
Try putting the old fuser back and see if it gets rid of the error, then if that's the case the new fuser is defective. If not, here's a link to the Lexmark website which gives you instructions on what to do when having that "Invalid Engine Code" error message. http://bit.ly/9D61W3. Hope this helps. Let me know if you need more assistance.
Apr 16, 2010 | Lexmark Optra T612 Laser Printer
Lexmark LP4037 5E-ERROR CODE 923,WHERE CAN I FIND FUSER OR HOW CAN I REMOVE THE ERROR
1. Enter the Configuration Menu by holding down the SELECT and RETURN buttons while powering on the printer until the display reads PERFORMING SELF TEST. After the self test, the display will read CONFIG MENU
2. Select individual reset for fuser or ITU kit
Jan 31, 2010 | Lexmark C762 Laser Printer
925 service fuser error
A 925 Fuser Error indicates that the wrong fuser lamp or the incorrect fuser assembly is installed.
  1. If this error appears shortly after the fuser unit in the printer is replaced, put the old fuser unit back in.
    If the error message goes away with the old fuser unit, please check that the new fuser unit is the correct one for this printer model.
  2. If the printer has not recently had its fuser replaced, plug the printer directly into a wall outlet. Surge protectors and power strips can sometimes regulate the voltage to a fault for the printer. If the printer is already on a wall outlet, plugging the printer into a different outlet may solve the problem. Keep in mind that there is no need to have the printer connected to a computer during testing for a fuser error as any pages to test the functionality of the printer can be processed internally.
  3. If you have tried the printer on other wall outlets and the 925 Fuser Error still appears, the printer will require service to clear the message.
Jan 12, 2010 | IBM Infoprint 1352 Laser Printer
120.07 Service Fuser Error
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model C530dn, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
Jan 04, 2010 | Lexmark C530dn Laser Printer
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
Jun 26, 2008 | Lexmark E342n Laser Printer
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
