Question about Tomtom GPS
Voice on the 300 sounds like a broken speaker
  • Tomtom Master
  • 2,130 Answers
Have you tried plugging a set of headphones into the headphone jack? If the sound is good there, then you indeed have a bad internal speaker. Please email me at ks3r at sharc dot net and I can give you a quote to replace your speaker. I have references.
- Jim
Posted on Sep 15, 2008
Speakers have sound and voices but not clear on 2007 Chevrolet Trailblazer LS
Static is the antenna. Noise the that goes up and down with the engine RPM's is the condenser on the engine. Fuzzy/cracking noise is a broken speaker.
Aug 12, 2016 | Chevrolet Cars & Trucks
Why do i get static rather than a clear voice on my tomtom ease unit?
either voice file corrupted or speaker is broken inside.. try changing to another voice and see if still sounds bad.. might have blown a speaker sounds like to me.
Jan 03, 2015 | Tomtom EASE GPS
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Fender fm212 cutting out
Put you hand into the speaker and try to wiggle it and see if it makes sound in a certain position and not in others. This will prove whether or not the speaker has a broken winding on the voice coil. I would definitely verify the speaker condition before thinking the amp is the problem.
Mar 04, 2013 | Fender FM212 Solid State Electric Guitar...
Had the subwoofer tested at an audio shop but they wanted to sell me a woofer. It makes no sound at all. A power issue? there was no problems with the 300 watt Kicker amp.
if the speaker cone moves it should produce some sound if it doesn't move when power is applied then the voice coil is frozen.
not really a power issue unless its a "powered sub" and if that's the case then you should not be running in high level sound using speaker wire (especially off a 300 w amp) but instead a low level signal via RCA cable.
Dec 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
My friend jus bought 2 10 inch kicker l5s and when we hooked them up to his boss 1100 wat amp and hooked everything up they are moving but are not producing any sound. boss amp i do not know any thinbg...
it must be reversed polarity in coil voices of speakers check + - wires from amplifiers fit on coil voices of speakers try to get each speaker to 8 ohms wiring in serial the two coil voices n'd put in paralel both speakers in bridge mode output from amplifier to get most stable power ,
Nov 04, 2009 | Kicker Solo-Baric L5 Car Subwoofer
Voice Call Problem
does this problem exist when you have the headset installed? is the sound quiet when headset used? if your sound is ok when in headset mode but not in ordinary mode,then there may be a speaker issue here... it may have excess dirt trapped in the tiny grille where the sound exits or the speaker may have sustained some damage by excess dirt pushing through and damaging it... or you could be really unlucky and just have a speaker that has just given up... check these solutions before you decide to go further
hope this helps
Dec 05, 2008 | Sony Ericsson K850i Mobile Phone
How do i open the speaker to reconecct the wires inside?
It may not be only wires loose; the speaker(or speakers) may be damaged.
The common 'dynamic' speaker has a centered magnet in an assembly that extends the field of the magnet around a coil of wire on a form called the 'voice coil' that is firmly attached to the cone which moves in and out to 'pump' air and produce sound.
The clearances (gap) between the magnet assembly and the voice coil that sits in a narrow space between the magnet and the outer field piece is very small and critical.
Once positioned in the factory, glue is used to keep the field assembly from slipping and rubbing against the voice coil.
A strong shock will break the glue bond and, if severe enough, clamp the voice coil so it cannot move freely any more.
Since the Bose is a quality product, the cabinet may be assembled with glue and screws that are concealed.
If you know someone with a simple multimeter, they may be able to check at the terminals to see if there is any continuity from the terminals to the speaker.
If it doesn't have any, then perhaps only a wire is broken between the terminals and the speakers.
There is with high probability also a filter inside that separates the frequency range and sends the signal to separate speakers that produce different ranges of sound.
Jun 26, 2008 | Bose VCS-10 Center Speaker
No sound comes out of the speaker. The volume settings are correct. The sound is on, and the volume is all the way up. What can I do?
Your problem can be one of several. 1/ you have lost / deleted / corrupted the voices on your SD card. if there are no voices then you won't get any nav instructions. 2/ Your speaker has stopped working , if faulty it will need replacement. ( not unknown and common on early tomtoms ) . On other tomtom models that have an external speaker socket the socket becomes faulty. This socket has a switch that switches the internal speaker OFF when an external speaker is plugged in. If this switch is stuck OPEN then that connection to the internal speaker is lost. However , the Tomtom drums sound is connected to the speaker via a different route so doesnt get switched off by this socket switch so the drums can still be heard.
Dec 25, 2007 | Tomtom GO 300 GPS Receiver
GPS Logo
56 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
