Do i need a router to set up a wireless network if i have a wireless pci card installed?
  • 104 Answers
Yes you need to have a wireless router to transmit the data.Your pci card will pickup the wireless connection and you get connected.
Posted on Sep 14, 2008
How to connect my hp pavilion 7915 desktop to a wifi network ?
The HP Pavilion 7915 will need a wifi network adapter card to connect to a wireless network. You would need to add an wired network interface adapter card to use a wired network, instead of a dial up connection. Check the height of your computer - a "Low Profile Card" may be needed. There are several versions of the 7915.
You can get a USB network adapter or a PCI slot card for either type of network from most computer stores. Depending on which version of the 7915 you have, you may have a limited number of USB ports. In that case the PCI card may be a better option assuming you have an available slot. Other models only have one PCI slot which can be blocked by a VGA card.
What OS is on your computer? I see some models shipped with XP and others with an older version of Windows. You will need to find a card that has drivers for your OS. Finding XP drivers will be easier than those for the older versions of Windows. Depending on the unit you order and your OS, the drivers may be already be installed in the OS. In that case, plug it in and go.
If you go with a PCI wireless network interface card, turn off the computer and unplug all of the wires before opening your case. Ground yourself relative to the computer by touching a metal part of the case before continuing. Remove the slot cover screw (hex head with a Philips slot) (for most desktops) from an available slot. Push the section of the card with the gold contacts fully into the slot. Work carefully and keep the slot section of the card between the case and motherboard. Press firmly and make sure that the card is level all the way across. Then screw the slot bracket down. (Note: you could remove the fax/modem instead of the cover if you do not need the modem.)
For a USB interface option, just plug it in. When the drivers are installed (follow the directions), attach the wifi antenna (if needed). Try to identify available networks (in XP click Start > Control Panel > Network then go to the network wizard to add a new network). Use the network ID and password for your wireless router. (I assume there are other wireless devices and the router has been set up; many older models need to be attached to a computer via a wired ethernet port for the initial set up. Most models have an initial name and password that should be changed.)
I hope this helps. If you have additional questions, please provide more information about your computer's OS and available expansion options. Also indicate what router you are using.
Oct 27, 2012 | Computers & Internet
Tip
How to setup a Wireless Network
1. <b>Connect Your Wireless Router</b> <br /><b>a.</b> Power off your cable modem and your wired PC.<br /><b>b.</b> Unplug the Ethernet cable from your cable/DSL modem and plug it into one of the LAN ports on the back of the wireless router. Leave other end of the cable connected to your PC.<br /><b>c.</b> Connect another Ethernet cable between your modem's Ethernet port and the wireless router's WAN port. (The WAN port should be separate from the other grouped LAN ports.)<br /><b>d.</b> Power on the modem and watch for the status lights to indicate that it's connected to your Internet service. This may take a minute or so.<br /><b>e.</b> Plug in the router. The status lights will blink as it runs through its diagnostics; this may also take a minute or so.<br /><b>f.</b> Start up your wired PC.<br />2. <b>Configure your Wireless Router</b><br /><b>a.</b> Refer to the router's quick-start guide, launch Internet Explorer, and type in the address indicated in the guide.<br /><b>b.</b> Follow the on-screen setup wizard, which will guide you through the process step by step.<br /><b>c.</b> Enable your router's security functions. This is very important if you don't want other people attaching to your wireless signal. The options will be WEP and WPA. Both will ask you to enter a key. Depending on the router's manufacturer, you may have to go into Advanced Settings to accomplish this step.<br /><b>d.</b> Change the default administrator's password, Almost all hackers know them.<br /><b>e.</b> Change the SSID-the name of your wireless network. Again, hackers know many of the default SSIDs and can use them to hack your network.<br />3. <b>Install a Wireless PCI Card in a Desktop PC</b> <br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Remove the cover.<br /><b>d.</b> Find an available PCI slot and remove the slot cover from the back of the PC.<br /><b>e.</b> Carefully insert the antenna through the open slot in the back of the PC, carefully push the card in the slot, and secure it. Replace the cover. <br /><b>f.</b> Start up the PC. It should recognize and install the new PCI card.<br /><b>g.</b> Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router.<br />4. <b>Install a Wireless PC Card in a Notebook PC</b> <br />Many notebooks have built-in wireless cards. However, If yours doesn't, you can install either a USB wireless adapter or a wireless PC card just follow these instructions.<br /><b>a.</b> Refer to the card manufacturer's quick-start guide. If necessary, run the software installation program.<br /><b>b.</b> Power down the PC.<br /><b>c.</b> Plug your USB wireless Adapter or wireless PC Card into an available slot on the side of your notebook.<br /><b>d</b>. Start up the PC. It should recognize and install the new PCI card.<br /><b>e</b>. Go to the Control Panel, select Network connections, select Wireless Networking connection. Click on Properties button. Click on Wireless Networking tab. Select the wireless networking name (see step 2e). Click on Configure button. Configure your security settings to match the ones on your wireless router. well, thats pretty much it. Hope this is helpful to all you home networkers.<br />
on Jul 11, 2011 | Computers & Internet
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
Cant connect to wireless network,
To connect your ThinkPad to your wireless router, the wireless card in the ThinkPad needs to be configures with the router's wireless settings, ie. the SSID and encryption key etc.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 11, 2011 | IBM 42T0933 - Lenovo ThinkPad SL400,...
Dont have a wireless card on one of my desk tops can i get the net with a usb stick
You can install a PCI wireless card in the desktop computer or you can use an USB wireless device. Both of these devices can connect to your wireless router, but they need to be configured with the router's wireless settings.
If you do not have a wireless router, then you can get an USB wireless modem device that connects to the Internet that uses the 3G mobile network. The advantage of this, you can connect to the Internet anywhere you get mobile coverage with that Internet Service provider.
Mar 07, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
What to i need to upgrade my dell 2400 to be wireless and wifi
WiFi -- As for the WiFi card that is literally plug and play, particularly if you have the XP service pack w/ the wireless networking utility.
What you want to do is purchace a PCI wifi card. I usually get my parts from tigerdirect.com or newegg.com. Once you get it in, you will need to remove the screws holding on the side of the computer(usually the left pannel) and you will then see 3 small empty slots on the motherboard. you will slide in the wifi card untill the two hooks on the side of the slot click into place. (Make sure you are as grounded as possible before taking out the wifi card from the static free bag.) When you buy the wifi card, it will probally come with a cd with drivers on it. install those before installing the actual card.
Mar 06, 2009 | Dell Dimension 2400 PC Desktop
Need Ethernet port on PC
If you have a wireless router then the ethernet cable will go between the modem and the router. Then you need a wireless LAN card to connect the PC to the router
What model router and modem do you have?
PC wireless card
Jul 03, 2008 | D-Link DFE-530TX+ Fast Ethernet PCI...
Wireless internet
You must either have a wireless card installed or a PCI wireless card that installs into the side of the laptop. You must also have a wireless router/modem that connects to your ISP.
Oct 07, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
