Question about Frigidaire GLTF2940ES Front Load Washer
My frigidaire GLTF2940ES3 front load washer keeps making beeping noises even when not on. I have unplugged it until using it. Seems to work somewhat but it stops in between cycles, beeps and blinks continues working but makes some strange noises. Also a backward L shows up in the time section. Don't know what to do
  • Frigidaire Master
  • 2,699 Answers
Frigidaire has problems with their computer boards and it sounds like this is your problem,i've seen them shut down and then after a while start beeping on it's own just like your machine is doing and it was the board part 137006000
Posted on Dec 05, 2017
SOURCE:
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
Have you had a storm or power surge lately. May need a new electronics panel installed. That is what happened to mine. Once it is fixed, you should get a surge suppressor that is made for major appliances
Posted on Apr 27, 2008
IFIXALL
  • 869 Answers
SOURCE: FRIGIDAIRE FRONT LOAD WASHER MAKING STRANGE NOISES DURING WASH CYCLE
Depending on where you live use your local directory for assistance.
Posted on Jun 25, 2008
  • 3 Answers
SOURCE: the wash beeps all the time
I had the same problem about a year ago. Out of the blue, the washer would start beeping and blinking. While the washer would run fine, it was annoying. Anyways, I had the service guy in and he had to replace the control board panel (under warranty). Without warranty, the cost of the part would be ~ 150.00. It was fine after that.
Posted on Jan 14, 2009
SOURCE: Constant beeping
I have an ATF8000 that did the same thing, unfortunately when this happens the entire control board must be replaced. I bought it for about $130 from a local appliance repair shop who then installed it for about $50. In all with tax it was near $200 repair.
Posted on Aug 20, 2009
rcalorisian
  • 313 Answers
SOURCE: my front load washer keeps beeping even when there
Beeping is pretty vague, but here it goes. Read the very broad answer. Your answer will be in it. I hope this helps.
LOOK HERE
Posted on May 29, 2010
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from forum.appliancepartspros.com
Oct 19, 2015 | Washing Machines
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
Jul 24, 2014 | Frigidaire GLTF2940ES Front Load Washer
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
My front load washer keeps beeping even when there
LOOK HERE
May 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Washer cuts off at 7 minutes and will not do the
It be the carbon brushes are worn down on the motor, when it goes into the final spin.
Mar 09, 2010 | Frigidaire GLTF2940ES Front Load Washer
Constant beeping
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
The problem is a faulty Door Latch Assembly. The same thing happened to my Frigidaire front load washer. The part is easy to install, costs about 60 dollars and can be picked up at most appliance repair stores . To access the switch just remove the wire around the front drum gasket, peel back the rubber gasket beside the switch assembly then remove the two screws holding it in place. remove the three wire connector blocks and swap in the new switch. My washer was giving me error code 41 witch is a faulty control board. But the problem was in fact only the switch...
Sep 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
653 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
