Question about Maytag Atlantis MDE7400AY Electric Dryer
Loud Noise when drying....
I have a loud noise when the dryer is on. As the tumbler goes around it sound like something is hitting the side of the unit. Please HELP.....
  • 943 Answers
Hi thanks for the question tome iot sounds like the blower a rumbling noise and the dryer takes too long to dry so i would check that thanks the appliance doc
Posted on Sep 18, 2008
2 Suggested Answers
  • 760 Answers
SOURCE: Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Posted on Jul 19, 2010
Loud dryer noise when drying
sounds like bearing take off back and see if and black markes around the bearings only other thing it could be is the felt ring around the drum
Apr 05, 2014 | LG DLE5977 Electric Dryer
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Loud noise when i hit bumps and turn the sterling
chances are that noise is the ball joints telling you they are dry and have no grease and they should be replaces fairly soon
Nov 04, 2009 | 1999 Ford Explorer
Dryer makes loud noise, long time to dry.
This is joyce
Go to maytag.com and put in your model# and dowload your manuel. get some info on your type machine and the scamatics on it. I dont know the age but it sounds like its in the drum. may want to calll a technichian out to look at it. if I can help please let me know
thanks
joyce
Feb 13, 2009 | Maytag LSE7806A Top Load Stacked...
Loud Noise While Drying
Your rear drum bearing is dried up and need to be re-gresed with high temp grease
Jan 05, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
LOUD NOISE WHILE DRYING
remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
292 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
