Question about Frigidaire Refrigerators
FRIGIDARE FRS26ZSEB: Freezer side, bottom collects ice and then leaks out the door.
    President:
  • 1,952 Answers
If the water is running down into the refrigerator section, This usually means the drain is blocked. Look in lower section at the top center ( you may have to remove control panel to get access) remove the drain cup gentle with screw driver from each side, clean , from under unit at the back locate the drainage tube, having someone holding paper towel from were you removed the drain cup blow into the tube to clear any blockage that might be in tube, re-install drain cup.
This should clear water leakage problem. 2) Icemaker You may have 1 or a couple problems here. First problem may be the water valve may not be closing fully allowing a small amount of water to continually leak into the icemaker.
Solution Replace water valve
Second; The problem may also be with the freezers defrost thermostat, If this is the problem though it usually means your food is also freezer burnt, Means the unit when in the defrost cycle is staying on to long allowing to much heat to be generated in the freezer compartment.
Solution: Replace the defrost therostat
Posted on Sep 14, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
    Replace water valve
  • Frigidaire Master
  • 19,396 Answers
If you get ice in the freezer, start checking if the evaporator fan and the defrost system is working.
Try doing a complete defrost, ofthen this can solve the problem.
Cause for ice in the fridge can be evaporator/defrost syste, bad gasket, faulty thermistor.
  • Ginko
    Ginko Sep 14, 2008
    See also the following guidelines from Repairclinic:
    "In a
    self-defrosting freezer, poor cooling often results from a heavy frost
    build-up on the evaporator coils. You can't see these coils without
    removing a panel inside your freezer. But if you see any frost or ice
    build-up on the inside walls, ceiling, or floor of your freezer, it's a
    sure sign of frost build-up. And that's a sign of a problem with the
    self-defrosting system.
    Freezers should self-defrost three to
    four times in 24 hours. But if a component in the self-defrosting
    system fails, the freezer continues to try to cool, instead.
    Eventually, so much frost builds up on the evaporator coils that the
    circulating fan can't draw air over the coils. There's still some
    cooling because the coils are frozen. But with no air flow over the
    coils, the cooling is quite limited and the freezer isn't as cold as it
    needs to be.
    An easy (though often inconvenient) test of
    whether the problem is with the self-defrosting system is to remove all
    of the perishable food from the freezer, turn the thermostat to Off,
    and leave the door open for 24 to 48 hours. (Keep several towels handy
    in case the melting frost and ice overflows the drip pan). This
    "manually" defrosts the freezer. When the frost and ice build-up has
    completely melted away, turn the thermostat back to a normal setting.
    If the freezer then cools properly, it indicates a problem with one of
    these components in the self-defrosting system:
    • The
      defrost timer. To test this, manually advance to the defrost cycle. The
      unit should advance itself out of the defrost cycle in about 45 minutes.
    • The
      defrost thermostat (or bi-metal switch). This thermostat allows current
      to pass through it at temperatures of 20 to 30 degrees Fahrenheit and
      prevents current from passing through it at 40 to 60 degrees (depending
      on its design). This is difficult to test, though, because it takes a
      prolonged, very-cold temperature to turn it on.
    • The defrost heater. You can test this for continuity using an electrical meter.
  • Ginko
    Ginko Sep 14, 2008
    Generally icing up is because the defrost system is broken or fridge is not cooling enough, in old fridge this is often due to problems with the condenser , see also this link: Cooling is poor
Water collects on bottom of side by side freezer forming ice. Water leaks from door.
The water leak is more then likly to be a condensation problem not helped by a bad seal around the door. This would need an enginneer really.
Aug 03, 2010 | Kenmore 44273 Side by Side Refrigerator
My GE Profile PS123SGPA BS side by side keeps dripping water from the water dipenser
Frigidare Model FRS26H5AS Side by side HELP!!!
Water collects and freezes in the bottom of my Freezer eventually leaking out the freezer door.
Thank you!!! bstrickmaker@neo.rr.com
Feb 15, 2010 | Frigidaire FRS26H5AS Side by Side...
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Amana bottom freezer: water leaking & ice build-up
There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Whirlpool Refrigerator(side by side) leaking water
First question would be is your ice machine leaking? If so then disable the ice machine until we can find the cause of leaks and repair them. Is the freezer freezing well? Food compartment temps OK?. Let me know and I will work to help you resolve this. Sea Breeze sea breezehvac@yahoo.com
visit my site below
http://servicepartstec.blogspot.com/
Mar 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
162 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
