Question about Sharp R-1870 Convection/Microwave Oven
Broken latch microwave door - won't open
Hi - Did you successfully remove and replace your microwave door back in Feb? The bottom latch of my door broke and I stupidly closed it. Now it won't open and I'm afraid I'll break one of the lock sensors. Also, where did you get your replacement door?
Thanks!
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Posted on Dec 07, 2008
  • Sharp Master
  • 9,047 Answers
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
Posted on Sep 16, 2008
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Oct 26, 2013 | Sanyo Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Dacor dcm 24s one broken safety door latch- door open button not
If the broken part is in the door, you will not have to pull the oven out of its place.
If the broken part is in the door open button area, you will have to remove the oven and take off the outer cover. Chances are it will be a broken "door open lever".
Assuming it's a door latch, you can use a thin strip of plastic to open the door.
It has to be somewhat firm but very flexible because it will have to bend at a right angle.
I have a flexible ruler I use for this.
You have to first shove the plastic strip into the crack between the door and the control panel frame about halfway up the door.
Then the strip will need to be maneuvered so it will bend to the left. Do this by pushing the rear end of the strip down as you continue to push it forward.
It may take a few tries.
Once you have it between the back of the door and the front seal of the cooking cavity, pull the strip straight and firmly up and it will lift the upper door latch and the door will open.
(If the upper latch is the one that's open, you have to start with the strip at the bottom edge of the door instead of the middle).
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly and troubleshooting tips, and the parts list is here.
Most computers will open these documents automatically, but you may need the free Adobe Reader.
You can order parts
here.
Once you have the door open, you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Jun 03, 2009 | Dacor DCM24 Convection/Microwave Oven
Sorry, but you will need to remove the oven from the wall or mount, then the outer cover will need to be removed.
We have the full service / repair manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
In Canada, you can find Dacor parts at these distributors:
Reliable Parts, Ltd
85 North Bend Street
Coquitlam, BC V3K 6N1
604-941-1355
Eatek Services
312 Benjamin - Hudon
St. Laurent, Quebec H4N 1J4
514-332-0007
If those don't work for you, you may find others via this page.
Jan 03, 2009 | Dacor DCM24 Convection/Microwave Oven
MIcrowave
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Door won't open
Im sorry to say, but the housing will have to come off to unlatch the door from the inside.Not difficult ,Unplug the unit and remove all of the screws around the top of the housing cover if any,also
rear and both sides will have to come out.When they have all been removed, lift the rear of the top housing cover and pull back.You will be able to see where the two door latches are locked in place.With a screwdriver,you can push up on the bottom latch and the door will open. All this can be done without spilling the milk inside.Just slide the microwave around slowly to get to the screws.The broken part inside should be able to be replaced.Contact repair parts center.
Oct 31, 2007 | Danby DMW139 Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
1,865 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
