Question about ViewSonic VX2235wm LCD Monitor
Problem with monitor
My 22inch ViewSonic monitor comes on, but will only stay on for a few seconds and then goes off. The power indicator light stays blue. I turn the monitor off and then back on and it will stay on for a few seconds and then goes blank again. HELP!
    Novelist:
  • 159 Answers
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Posted on Oct 12, 2008
My viewsonic vs11661 will only come on for a second then goes off.
This indicates a high voltage problem, since smoke was seen, the cost to repair will exceed the value of a new one.
Apr 18, 2012 | Computers & Internet
Viewsonic monitor stays on for only 3-5 minutes and goes off . Then I turn it off an wait and it comes back on!!! what is going on??
I guessing that when you say "goes off" you mean it goes into power-saving mode? Assuming that you're working on the computer at the time (so it's not actually going to power saving mode from inactivity), this might indicate one of two things:
a) the VGA cable to the computer is not in a good contact with the monitor. This might happen if you haven't used the screws to fix it in place, just try to plug it fully in on both ends (computer and monitor). If the monitor sees to VGA signal, it goes into power saving mode automatically.
b) there's a problem with the monitor that builds up after a few minutes. When you turn it off, it "cools down" and can be used again. If that's the case, you should take it to a dealer's shop and have it checked (or replaced if it's still under warranty).
Mar 13, 2011 | ViewSonic Computers & Internet
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic VA702B
Monitor going black after a few seconds can be caused by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Jul 28, 2008 | ViewSonic VA702b 17" LCD Monitor
Screen won't stay on
This is a common problem with LCD monitors after a few years of use. The capacitors in the power supply board start to fail and this prevents the monitor from starting up correctly. Sometimes you get a picture and then it goes black. On some units you can keep pressing the power button and after several power up cycles the monitor will work until you turn if off. These symptoms are all common with capacitor failure. The monitors are well out of warranty now so Viewsonic will not cover the repair cost. But the repair is very easy to do yourself. You just have to replace the 6 power filter capacitors on the power supply board. Here is a link to additional information on this repair.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=218
I hope this helps, I have repaired over 30 of this model with the same issue.
Mar 28, 2008 | ViewSonic VA902b 19" Monitor
Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Jan 14, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
ViewSonic VX2235wm LCD Monitor Logo
380 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
