Rca lcdx3022 When I turn it on a get a little flash on the screen and that's it. Any ideas? RC
  • 19,396 Answers
This happens when the tv cpu detects an internal problem, for example an overvoltage, a short, or a faulty component.
The tv goes in protected mode, and activates a safety switch that turn immediately the tv off, that is what is happening to your tv.
Try unplugging the tv for one hour or so, this will drain power from the unit, and reset the TV chips, in case the TV is "wrong" about the problem.
If it does not works it means that the tv has an internal fault, in this case you may need to call a technician if you want to fix it.
If you need to call a repairman you can use the phone number listed on the owner manual.
Posted on Sep 14, 2008
Rca 21k8. Insufficoent height
Warning!!!!!!!!!!
Do not adjust anything else only Vertical amplitude .1.1. The way to enter P-Mode a) Method one A) Switch on the TV set. B) Press the "MENU" key on RC to show the "PICTURE" OSD menu. C) Move the cursor to "Contrast" item then press the "9", "7", "3", "5" key continuously on RC within 3 seconds then enter P-Mode. The "P" letter will appear on the left low corner of the screen when enter P-Mode. China TV 21F1 NX56E LA Service Manual
Nov 25, 2016 | RCA Televison & Video
I have the above TV but my fiance accidently leant on the RC & now I've lost the picture.
take the batteries out of the remote and turn the tv on with the set control and see if it goes on
Aug 01, 2015 | Televison & Video
RCA LCDX3022 screen doesnt illuminate when powered on, Green light is on.
Sounds like a main board fault. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | RCA LCDX3022W 30 in. Television
My rca 52" D52W20YX1 tv has sound but no picture. what part will fix this
W ill need a little more information. Turn the sound down and listen at the back of the TV, Do you hear a ticking noise? When you turn the TV off do you see a flash on the screen?
Oct 30, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 22la45rqd no picture
Check the picture settings like brightness, sharpness, contrast and color. Change input device to something you know works for sure. Look for any loose contacts in RC jacks. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | RCA 22LA45RQD LCD TV/DVD Combo
RCA L32WD22 with no picture.
The backlight has failed. May be the power supply for it, the inverter board or the lamps. Not something you can fix unless you are a tech.
Mar 10, 2010 | RCA L32WD22 32 in. LCD HDTV
RCA D52W20 52 in. Rear Projection
the main pwr board is defective and will need replacement...
Oct 18, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
Electro Med Services...
