2002 Volkswagen Golf Logo
Posted on Sep 11, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vw polo abs light won't go off. I've replaced the 40 amp strip fuse located in the fuse comparment above the battery but it still hasn't gone off even thought the orginal fuse was blown. Anyone got any other ideas ?
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on Sep 11, 2011
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2962634
Points
18833
Well, first of all, did you fix the problem that caused the fuse to blow? Have you scanned you Antilock Brake System (ABS) module for fault codes? Since the computer is the one responsible for turning the light on, wouldn't you think that the computer would be the one to ask WHY it has turned the light on?
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
2015 VW Polo sedan. The power steering light is on so want to check if the fuse is out.
Question edited for clarity.
Question move to Polo Category.
Fuse Box Diagram Volkswagen Polo (6r/mk5; 2009-2017)
https://fuse-box.info > volkswagen > volkswagen-polo-...
The fuse box is located behind the cover below the steering wheel. The location of the fuses in the passenger compartment: Volkswagen Polo (2009-2017. The ...
Volkswagen Polo 5 / 6 - fuse and relay
https://fuseandrelay.com > volkswagen > polo-sedan
Complete information on all fuse and relay boxes in the Volkswagen Polo mk5 mk6. Locations, photographs and box diagrams with the designation of elements.
5: 5A Power package control unit
2: 30A Cooling fan motor control unit, cooling f...
1: 25A ABS control unit
3: 5A Cooling fan motor control unit
1helpful
2000 Chrysler 300 Battery Drain / Multi-Fuse Drain
I believe the glove box light stay on or the trunk light , all the best.
1helpful
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
"one wheel locked up"
has the wheel bearing or break shoe perhaps seized
2helpful
Abs light has come on saab93
THE ABS WARNING LIGHT HAS COME UP
It means there is an issue with the anti lock braking system (ABS). If the warning light has come up it is likely that the ABS is no longer functioning. It is still safe to drive the car and it will brake as normal but the anti lock safety feature will not operate.
You need to have it checked out for faults. The most likely cause is a failed ABS wheel speed sensor which needs to be replaced. There could alternatively be a problem with the ABS pump which is causing the warning.
There is one item you can check yourself. There is a dedicated fuse for the ABS pump/motor. Check the owner's manual and locate the fuse for the ABS motor and check that the fuse has not blown. If it has blown replace it with a fuse of the correct amperage and road test the car. (So if it is a 40 amp fuse for example, make sure a 40 amp fuse is used to replace it.)
Cheers
I have a 2000 VW Beetle. My ABS light has been on for a while and last night my brake light and battery light beeped a few times then kept blinking. They finally shut off then about a couple of hours later...
I suspect bad brake pedal position (BPP) switch. Check & replace if necessary the brake pedal position switch placed above pedals on the support.
The best idea is to access the ABS ECU (Electronic Control Unit) using diagnostic equipment (VAS, VAG-Com, or similar) connected to the data link connector of the car, in order to pull out all DTC's (Diagnostic Trouble Code) memored. Then you will be able to replace bad piece(s) and fix the problem by erasing all DTC's stocked inside ABS ECU & reset it.
Good Luck!
16helpful
2answers
Fuse box layout for a 2002 VW Cabrio
Fuse colors
30 A-green25 A-white20 A-yellow15 A-blue10 A-red7,5 A-brown5 A-beige3 A-violetFuse locations
Fuse Location
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1-Headlight, Low Beam, Left (56b)102-Headlight, Low Beam, Right (56b)103-License Plate Lights (58) 104-Rear Window Wiper And Washer System155-Windshield Wiper/Washer156-Fresh Air Blower, A/C (X)207-Tail Lights, Right (58R)108-Tail Lights, Left (58L)109-Rear Window Defogger2010-Fog Lights1511-Headlight, High Beam, Left (56a)1012-Headlight, High Beam, Right (56a)1013-Horn (15)1014-Back-Up Lights1015-Engine Electronics (15)1016-Power Sunroof, Front Map/Reading Light1517-Emergency Flashers (15)1018-Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module2019-Coolant Fan, A/C Relay (30)3020-Brake Lights (30)1021-Interior Lights, Clock, Luggage Compartment Light (30)1522-Cigarette Lighter, Radio, Luggage Compartment Release10Separate Fuses
(Located above the relays)
-Fuse for ABS hydraulic pump relay30-Fuse for ABS main relay30-Fuse for A/C30-Fuse for power windows20-Fuse for cruise control5-Fuse for cigarette lighter15In the engine compartment above the brake booster:
-Glow plugs50
5helpful
Hydrolic Air Pump Abs Light
Very common on these models is the fuse link in the top of the battery cover (40A) cracks. Costs a couple of pounds but indication on code reading is ABS pump failure.
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
