Question about Amana Kitchen Ranges
Amana Range Electric Smoothtop Easy touch Control 800, oven won't heat.
Our range starting beeping twice. When I tried to use the oven, both bake and convection, it would take the temperature, then beep twice and cancel. The burners on top do work. I unplugged the range to try and reset, but now I can'y even set the clock and the only beep i get is when I touch cancel Any suggestion on what's going on? Thanks, Kevin
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Posted on Mar 24, 2008
SOURCE: After running self cleaning cycle, oven won't heat.
I own a similar range. As you can imagine I was dismayed to find out that my $6000 heap can't run a clean cycle, unless of course you just don't want to use your oven again. let me give you a tip something WILL break on your oven every time you use the self cleaning "feature".
The first time I used the self cleaning feature the board burnt up, I asumed hat this was a fluke. The second time the pvertemp sensor burnt out. The next few times that I was brave enough to try it the overtemp sensor triggered this is what I hope has gone wrong with yours since while it's not easy or convenient to fix it is free. If you pull out your range and remove the backsplash and then the rear panel there should be a breaker with a button you can push to reset. On mine it is located near the top of the oven compartment on the left side near the middle. I hope that works for you and you will soon learn as I have after doing this a few times that the self cleaning cycle is just not worth it. It willdo this every time and it really is just easier to use easy off and clean the oven by hand. I realize that is not what you had in mind doing when you bought a luxury Item like a 36" thermador range, but I hope you don't have to hate yours as much as I hate mine.
Posted on Oct 28, 2008
  • 12 Answers
SOURCE: Amana Electric Range Mod# AER5715QAW bake element not wokging
replaced the electronic control
Posted on Jun 14, 2009
fixyourboard
  • 310 Answers
SOURCE: Amana Range, AER5515QAW
could be a bad bake element, bad temperature sensor, or control board problem
what does the oven readout display for temperature? if the readout agrees with the actual oven temperature ... it is probably the element
if the oven readout displays a much higher temperature it may be the temperature sensor (the probe in the oven cavity) or the control board
the temperature sensor can be tested by measuring its resistance with power off and unplugged from the control board, should be about 1100 ohms at 75F
If the sensor is good, then it is probably the control board ... in which case we can repair it for you at www.fixyourboard.com
Posted on Jul 21, 2009
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Elite electric range smoothtop
Yes, you can repair the appliance yourself and save on the cost of labor and services charges. Unfortunately, when these triple burners go bad in the manner you describe, there is no way to repair only the portion that is burned out. The burner is one complete piece and needs to be replaced as an entire assembly. The following link explains how:
http://www.fixya.com/support/r3692628-surface_burner_replacement_electric
Replacements parts can be purchased from any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. I suspect your model number is actually 790.96593601 or 790.96593602. These are the only two numbers that cross to the model number you provided. If I'm not correct, please post back with your COMPLETE model number.
The part number for the triple burner is 316216702. Keep in mind, this part, alone is not cheap. The cheapest price I found was about $120 at appliancepartspros.com. However, you would spend much more if you included the added price of a service call and labor charges. Use the part number provided to search any other web sources you like to see if you can find the burner listed elsewhere for a better price. Use the part number as some websites may not list your particlar model, but will carry most parts.
If you have any questions please post back and let me know. I hope this helps you.
Posted on Apr 30, 2010
When using oven it beeps twice and oven light comes on and oven shuts off
[PDF]Bosch Hbl8650uc Use And Care Manual - Cloudfront.net
https://d1vofmza27mmhi.cloudfront.net/.../bosch-hbl8650uc-use-and-ca...
foods with the appropriate oven mode, temperature, rack position and bake time. This section also ..... Preheat. Light. Lower. On/Off. Upper. True. Convection. Speed. Convection. Broil. Bake. Roast .... Cook Time: Turns off beep for the end of cooking time. •. Timer: Turns off ... Press Timer twice to exit the timer menu. Note: •.
PDF]Use and Care Manual for Bosch Electric Built-in Single ...
pdfstream.manualsonline.com/.../9d658fa3-efaf-44a3-beb6-bc5f9c80d5...
realize the full potential of your new Bosch oven as well as protect it from damage ..... On/Off light. • Heat light. • Door lock light. • Timer/Manual selector knob .... the display will come on showing all the call-outs, .... Electronic Control of Oven. Immediate. Start/Automatic. Shut-Off. To use the .... Depress Cook Time button twice.
Dec 02, 2015 | Bosch HDI7152 Stainless Steel Dual Fuel...
We have an Amana Easy Touch Control 500, the pilot is on but oven won't heat up. We also can't self-clean because the door won't lock or sometimes it locks and won't open. I suspect the...
Most likely the door for your kitchen range has a sensor that is not allowing it to heat up because it detects that the door is not closed.
I would suggest you consult help from a certified technician by the manufacturer of your Kitchen range that way they would also be able to check other possible faults on your kitchen range and replacement parts would be 100% compatible.
You can also check the services that these guys offer:
http://www.stoverepairnearyou.com/ml2/?v=1640662349&u=08E0B192DFA88BAA0210818080F80718DDA9032090DEAEEC8F8CA8CFC401
Hope this helps!
Jul 18, 2011 | Amana ACF4225AS Electric Kitchen Range
F-1 message
F1= Defective Touch Pad or Membrane Replace Touch Pad or Membrane
May 28, 2010 | Amana AES3760BAW / AES3760BAQ / AES3760BAB...
I am trying to replace a burner on my amana smoothtop electric range. I have removed the three screws above the overn door (inside). The top is loose but something seems to still be holding it. Any...
most ovens usually have 2-3 screws located along bottom edge of the smoothtop in the front..check the far left and far right corners in the front /if all screws are removed,you may need to pull slightly forward then raise
Mar 06, 2010 | Amana AER5715QAS Electric Kitchen Range
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oct 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire cooktop beeping f7
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 19, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
1-800-905-9505
They answer 24/7
Thank you Neil
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
316 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
