Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Tv turns off
After watching for a few min. the tv turns off and the power light blinks three times, can i repair this at home?
  • 1 more comment
  • jgrieser24 Sep 29, 2008
    My tv
  • jgrieser24 Sep 30, 2008
    My TV turns on for a few moments then turns off, then back on for a second, and off again and so on. Can I fix this problem at home?
  • Anonymous Nov 22, 2008
    i have the same 3 red flashes.
    i got a new lamp, but didn't do anything
    what are you refering to when you say a lamp cover
    i got this black box with a lamp installed into it.
    i simply pushed it into its connection attachment (lined up the pegs)
    but still nothing but 3 flashes
  • 10,594 Answers
3 times blinks shows error as Lamp Cover not attached securely. Please check lamp cover of tv.
Need further info, please let me know.
Posted on Sep 14, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
TV will not turn on Yellow power ind. Light blinks three times tried to reset no luck took to repair shop diagnosed with bad SEIN module internet post suggest bypassing Sein module but I don't know where...
Toshiba Regza 37in - 37HL17
TV will not turn on Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
cc46e8cd-c98d-439a-bc78-207613c68534.png 76bab8a5-e5dc-4d5d-9d56-589661460254.png
Jan 13, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Had a power outage while watching tv. Then 3 blinking lights.
This is an on-going problem with DLP sets. Normally you shut the set off and the cooling fan cools the lamp down and then it shuts off. In your case, of which it's not your fault, however your lamp has taken a major hit by not properly cooling down, in turn, you need to replace your lamp at this time.
I suggest in the future if you have an electrical storm and a chance of a power outage while your watching tv, I would'nt play that model or any other model of a DLP set.
Jun 23, 2009 | Samsung HL-S5087W DLP TV
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
TV turned off and now the power light blinks three times
Very common problem. 3 blinks means the convergence circuit has failed . Heres a link to the repair kit for your model which contains both convergence IC and the feed resistors and the kit has step by step instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits/osCsid/e28ca8f8240833facd92d8890ef7e2b2
Jan 19, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Hitachi power light blinking
Does anyone know how to fix this very common Hitachi problem without paying a repair man? And if you did pay a repair man did they fix the problem, and how much was it? I absolutely LOVED this TV before this happened. :(
Jun 21, 2008 | Hitachi P50H401 50 in. Plasma HDTV
After power outage, tv doesn't turn on
First, the blinking light is a code, how many blinks? Second, regulators are not resettable. Don
Aug 17, 2007 | Panasonic CT-36HL43 36" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
