Question about Dometic RM2652 Refrigerator
Dometic rm2652 re-ignitor
Just purchased 2005 trailer. The first time out the Dometic rm2652 fridge works, but, the re-ignotor constantly clicks to ignite the gas after it is already lit. Tried ignoring it to see if it would eventually go out and it does, after the voltage drops below about 9.5. Is this normal?
To continue use on our trip I would let it start/light and then pull the yellow wire from the reignitor. When the check light would evetually come on because it could not reignite I would have to reconnect the wire, let it light, and then disconnect it again. The reignitor gets its voltage directly from the the same wire or signal that opens the gas valve. It looks like it is operating normally according to the schematic but it does not seem right, to have to listen to clicking sound constantly until the voltage drops.
  • graytw Sep 14, 2008
    The suggested remedy resulted in the ignitor rapidly clicking as usual but with the electrode disconnected, no spark. Expected result. The ignitor begins firing away as soon as the gas valve is open. This would be expected but then how does the ignitor know when to stop igniting after there is a flame? It is wired directly to the gas valve solenoid as the schematic says it should be.
    It is an automatic temperature controlled fridge. So I believe the flame goes out when cold enough then reignites when necessary for the temp to remain cold. The problem is I need to remove the yellow + wire from the ignitor to stop the continuous clicking, then it cannot reignite when it needs to so the check light comes on.
    Thanks for the service manual. Here is a description of reignitor operation;
    "On gas operation the igniter senses the resistance
    through the flame between the electrode
    and burner. When there is no flame at the
    burner, the resistance is high and the igniter
    begins sparking to light the burner. As soon as
    the flame is lit, the resistance between the
    electrode and burner drops and the igniter
    stops sparking. The resistance is monitored by
    the igniter, and, if for any reason the flame
    goes out, the igniter begins sparking until the
    burner is lit."
    My electrode sparks fine but when it sees flame is the resistance not dropping as described to disable the ignitor? Is that possible, it is just a wire and it sparks fine?
    It is not grounded, what is it resisting?
    Genius:
  • 1,011 Answers
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
Posted on Sep 14, 2008
  • Dometic Master
  • 19,396 Answers
Here you can also check the entire service manual:
Manual Refrigerator Diagnostic Service Manual
Thanks for using Fixya.
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Dometic rm2652 Have this fridge in my travel trailer and it gets way too cold about 10 degrees farenheit. I moved the thermistor to the center like suggested in some other posts.
the thermistor is faulty and needs to be replaced or it is too close to the cooling plate , try relocating it if you can and if it continues , replace the sensor. Hope this helps
Apr 15, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic rm2652 recall
You wll see a metal shield around the burner tube, a dealer has to do the recall as far as I know.
Sep 14, 2008 | Dometic RM2652 Refrigerator
Dometic refridgeratorinstallation
Verify your connections you have voltage supply problem most likely on your DC
Jul 05, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
1,507 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
