Question about CyberPower Office Power 585AVR (obcps585avr_1) UPS System
When power goes out, it turns off.
Could the batteries be out of recharge?
  • Anthony LaRosa Mar 11, 2009
    I just got a new battery but it was a fuse not the battery I paid 15.00 you can have it for 10.00 P Shipping
    jrrosa231@yahoo.com
    Hi My cyber power 585 AVR stopped working on the battery side I change the battery and it work after 2 yrs it happen again so I got a new battery but after a day of charging I didn't work so I open it up and now I see the 40 amp fuse how can I get one or where
    so if you need a battery I have one ,I paid $15.00 you can have it for 12.00 + shipping
  • 26 Answers
One of two issues is likely causing this:
1. There is too much plugged in to the battery outlets on the device for the unit to provide backup.
2. More than likely it just needs a new battery. You can find a battery here: http://www.batteryinternational.com/cyber-power-cps585avr-ups-battery-ups-batteries-f1.html
Hope that helps and thanks for voting.
Posted on Oct 23, 2009
    Problem Solver:
  • 10 Answers
Yes, that could be the case. Eventually, a battery will be unable to recharge and would need to be replaced.
You could get a new battery from a local battery specialty store like Batteries Plus or Interstate Battery, or online at www.replacementupsbattery.com. A new battery would be about $30. If you took your old battery there, they could recycle your old one, as well as match it up with the correct one you would need (BP7-12 battery).
We have a 3 year warranty on all our battery back up units. If you have any questions, you could contact us here at CyberPower Systems Technical Support at 877-297-6937, M-F 8-5 Central, or email us at tech@cyberpowersystems.com.
Posted on Nov 18, 2008
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
Tip
HTC increase Desire battery life.
<span>Preparing...<br />With the phone in the on position.<br /><br />Fully charge the battery with the phone on... (until the led turns green.)<br /><br />Once the led turns green, unplug the charger until the led goes off. <br /><br />After the led goes off, plug the charger back in. When the led turns green , power off the phone.<br /><br />now.... with the phone fully powered off...<br /><br />1. Unplug the charger. <br /><br />2. Wait until led goes off. <br /><br />3. Plug charger back in until the led turns green. When it turns green, unplug the charger again and go to step 1.<br /><br />4. repeat steps 1 and 3, 10 times. This may take anywhere from 30 seconds to 30 mins per cycle. Typically only about 1 minute. though.<br /><br /><br />DO NOT DRAIN THE BATTERY. The goal is not to empty the battery and recharge like ni-cads (those have memory, these don't). These are lithiums, so we need to do the opposite...</span>
on Jul 11, 2011 | Cell Phones
The light on the end of the dock stays red. Battery when recharged turns green. When placed back on the dock, then the light goes back to red.
Turn your camera on and look at the battery life after you had it charging for a while. your rechargable batteries may be bad or getting bad. Try trading out the rechargeable batteries or try plugging in your charger on a different outlet at home
Mar 04, 2011 | Cameras
The lens goes out and in when turn power on
Probably the rechargeable batteries are low on power. THis will cause this exact same issue.
Batteries will discharge after a week or two of non use of the camera even if not turned on.
Nov 07, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Alarm goes off when recharging the battery.
try turning on ignition switch before hooking up charger, once charger is working turn switch off.
May 10, 2010 | 1992 Pontiac Bonneville
Camera ran out of battery,whilst zoom lense out.Replaced with new batteries but now when i turn the camera on it bleeps for about 3 seconds and then goes off.I cant even get it to stay on long enough to...
Some batteries (especially the lower mAh rechargables) don't seem to have enough power. Try putting in a couple of brand-new (non-rechargeable) Duracells, and see if that helps.
Nov 24, 2008 | Rollei Cameras
My sony cybershot wont turn on!!
The symptoms sound like a failing battery. The camera is shutting down due to insufficient power during startup checks. How old is your battery? Rechargeables really aren't meant to last more than a year or two.
Now I realize that Sony batteries are outrageously expensive. But thankfully there are generic alternatives such as:
http://www.amazon.com/CTA-Digital-DB-FT1-Rechargeable-Equivalent/dp/B0006JMJPY/ref=sr_1_4?ie=UTF8&s=electronics&qid=1225553784&sr=1-4
Oct 28, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Rechargeable batterie won't work in my Camera.
Not sure what camera you have, but some cameras require a very steady power supply voltage. Also not sure how old your rechargeable batteries are either, but batteries (alkaline and rechargeable decay over time. With the rechargeable ones, the more you use it, the less it can charge to full capacity over time. For example, if your rechargeable battery is supposed to charge up to 1.5V, over a period of a year with constant recharges, you can test with a volt meter and see that it never really goes back up to 1.5V, but more like 1.48V, 1.45V or maybe even 1.4V.
Depending on the camera or other item you use rechargeable batteries on, it can adapt to low voltages with special circuitry inside (but only to a certain limit, when a battery is old, it is old).
You can try buying a new set of rechargeable batteries and use it few times and see if this fixes the issue. If not, your camera may be faulty and just draining the battery (not too likely, but it happens).
Check out this site for some useful info.
http://www.steves-digicams.com/nimh_batteries.html
Apr 30, 2008 | Canon PowerShot S5 IS Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
CyberPower Office Power 585AVR (obcps585avr_1) UPS System Logo
156 people viewed this question
Top CyberPower Computers & Internet Experts
George Nalley
Level 1 Expert
Paul Bade
Are you a CyberPower Computer and Internet Expert? Answer questions, earn points and help others
