SOURCE: Sci Phone 168 tuns on but does'nt ring...volume
Hi. I'll try to explain but my english is not so good so please forgive me if my writing is too messy. I had the same problem and I discovered that the speaker system is very fragile. In my case the earpiece broke down because the phone fell down from about 2 feet but landed precisely on one of the upper corners, so when i decided to disassemble the phone to see what was going on I discovered that the speaker has two wires soldered to the "mainboard" but the back of the speaker also has to make contact with the board, so the problem was just that the speaker was NOT making contact with the "mainboard". I Just had to move it to the right position and "voila" the speaker was up and running again. No changing pieces, no soldering, Just moving a bit the earpiece, pretty simple, the only tricky part is to dissasemble the phone, you'll have to look up on the web how to do it and be cautious and patient. One final note, lately I've realized that my work was not so good because sometimes the speaker stops working but with a little subtle hit it's running again so I decided not to disassemble the phone again, it happened like two or three times but the last time was about 5 days ago. I hope this can be helpful to a lot of people with the same problem. Bye! Keep enjoying your sciphone!
SOURCE: usb stopped working
hello there! thanks for using Fixya.com!
I guess you already tried everything and that's bad sign. Well, I can suggest to you that check another USB cable and try it. If its still same problem, better consult your technician so that he can check it personally so that we will not do anything harm to your laptop. that's better i guess!
SOURCE: Hi, I have an LG flip phone and it only works
try setting everything back to DEFAULT SETTINGS , if its not that you need to send it back to where you got it....sorry if its from *b*y
SOURCE: Volume and microphone flucuation
This is a device issue. You will need to contact your service provider for replacement options!
