Question about Video Game Consoles & Games
Keep getting error 801.301.3d code when trying to connect ps3 to internet will not go past finding ip address
  • 400 Answers
SOURCE: ip address
change its setting from atomatic to mamula and then via using you computer go to RUN type CMD and then there type Ping you will get IP address from here then paste it on Ps3 internet setting..
Posted on Jun 23, 2009
Vahn84
  • 99 Answers
SOURCE: cant connect my ps3 psp go to the internet using
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. PS3,and PSP use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
Posted on Nov 22, 2009
albert_price
  • 190 Answers
SOURCE: What are error codes 801 301 3D and 800 1000A on
Error 801 301 3D is due to internet connection issues.
Check to see if your router has backwards compatibility to wireless G because the N router uses 256bit encryption coding while the G uses 128 bit encoding. ps3 , use the 128 encryption coding also. If the router does not support 128 bit encoding you will never connect with it.
And 800 1000A error means that you cannot download from the sony store. hence the connection problems from your first error.
Hope this helps you.
Correct? recommendation and vote would be aw some!
thanks.
Posted on Nov 22, 2010
  • 40 Answers
SOURCE: My son keeps getting annerror on his PS3-801 301
It may be a problem with the auto video mode selection that the system has. First while the system is on you can try turning the system off from the switch on the back of it. If that doesn't work try getting into the settings and restore everything to defaults for the system. Sometimes the system gets stuck on a specific setting while its trying to automatically adjust to different resolutions and what not.
Good Luck and Happy Gaming!
Posted on Jan 07, 2011
  • 40 Answers
Testimonial: "I know nothing about PS but I have passed this info to my son and hopefully it will work. Thank you so much for your time and expertis Stephen"
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Hello, can you help, on my ps3 it keeps coming up with error 80710102 and will not connect to the internet or find the wireless box
This is a common dns error with playstation.
try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary
Mar 17, 2010 | Sony Playstation 3 (PS3) Console
Trying to update to 3.0 but i get a 8002f165 error, it downloads the update but when it changes to installing it says that i have that error. i did update a hardrive a few weeks ago, but i don't think that...
Restore PS3 to factory settings and change your network settings:
Best Results: Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Also check your cable connections.
Now try updating...!
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
HELP?
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Ip address
Jun 23, 2009 | Sony Playstation 3 (PS3) Console
.trouble with playstation 3 getting on line through router...
It looks like there are a lot of DNS servers that do not work correctly with the PS3. Below I will list a few DNS servers that do seem to work and you will need to manually configure the DNS settings for your PS3 to any of these addresses.
208.67.222.222
208.67.220.220
129.250.35.250
129.250.35.251
4.2.2.1
4.2.2.5
Nov 01, 2008 | D-Link DI-604 4-Port Cable/DSL Router...
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Cant get internet on ps3
make sure that the ip address that you are getting is a valid one and you are connected to the correct wireless network. for example, if your router's ip address id 192.168.1.1, your computer should have an ip address of 192.168.1.x. if you are getting a valid ip address and you're still getting the dns error, the thing that you can do is set a static ip address and dns to your ps3.
if you don't know the dns to use, go to the command prompt and type ipconfig/all and it'll give you a list that'll contain the dns servers. copy the dns and enter it on the ip settings of your ps3 together with the default gateway (ip address of the router), subnet mask (it's usually 255.255.255.0) and your ip address (make sure that the ip address that you'll set on the ps3 is not being used by any of your computers)
hope this'll help you and just ask me if your still having any problem
ciao!
Jul 05, 2008 | Blitzz Technology BWA711 (B3WL000900)...
80710092
dns error, try entering the following in your ps3. Settings - Network Settings - internet connection settings - custom - wired or wireless depending on your internet - manual settings - IP address manual - enter your ip address and your router address and change your dns primary 208.67.222.222 and secondry 208.67.220.220 this will enable you to go online as for the error code 80710092 i have no idea, im experiancing the same problem. its so frustrating. as soon as i find the answer i will let you know.
Apr 14, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 dsn error 80710102
you will have to contact the internet provider and find out what there dns server ip address is and then enter it into your ps3
Mar 17, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
125 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
