Question about Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television
Blinking Red Power Light
While tv was on we experienced a brief power outage, lights in livingroom only flickered. 30 Min. later lost picture but still had sound 2 Min. later unit shut down power light began flashing red. Only way to turn on set at this point is holdind down volume- and input and then switch on power strip, does same thing no picture but still has sound shuts down 2 min. later power light begins flashing red. I did take a look at inverter screws but they are tight, I also used a flashlight while unit was on and could see video image so lcd screen is good just no backlights?
  • 4 more comments
  • jnsp Sep 16, 2008
    Tv is 3 yrs old , red light blinks consistently no breaks in between.
  • jnsp Sep 16, 2008
    Although sound still works , when you hit - or + button settings are off , loud and really loud no gradual increments.
  • jnsp Sep 17, 2008
    sharp lc 32ga5u
  • jnsp Sep 17, 2008
    Do you think I need to replace my inverters or power supply
  • jnsp Sep 17, 2008
    Only way to turn it on is by holding dowm vol- and input than turning on power strip.
  • Isaac Barone
    Isaac Barone Aug 11, 2013
    awsome thaat power strip thingg reallyy works thanks
    Genius:
  • 2,035 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..Try to plug different power source if this fails ,then you give it service center to get it fixed or you like DIY then :
I would recommend going to the following link and getting the service manual so you can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new board. heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 17, 2008
    Brigadier General:
  • 6,966 Answers
The blinking LED indicates that the built-in protection has been activated. However it would appear not to be a major fault, otherwise, the sound would also be gone as well as the dim video. Initially would suggest:
  • unplug from the mains for at least an hour (to dissipate power inside);
  • press the RESET button at the rear of the unit below the RS232C terminal;
  • press the SYSTEM RESET in the same area.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
BTW, Thanks jaznet for pointing my previous posting as a possible solution to this problem.
    Novelist:
    Champion:
  • 203 Answers
If you provide a model number I can assist your furthur.
  • 10,594 Answers
as you stated LCD is fine and tv just have not back light, its inverter problem.
You can get inverter board from HERE on very cheap prices.
Please let me know any update.
  • 75 Answers
It must be an inverter problem, try to see this page to get an idea how to fix this:
http://www.fixya.com/support/t365251-acer_travelmate_6291_lcd_monitor_problem
GOOD DAY!!!
Posted on Sep 16, 2008
  • 4,472 Answers
Does the light flash a certain number of times? how long have you owned the television? Once I have all the needed information I can provide you with the best solution.
Thanks,
Lee
  • 4 more comments
  • Lee A.
    Lee A. Sep 17, 2008
    I would recommend having it serviced professionally unless you are very confident in your technical ability. If you still need my assistance please accept and re-rate my solution accordingly. I can assist you if you have any other questions or would like to locate a service center nearest you.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    This is what you need to do as recommended by Sharp.
    Hearing a strange sound? A light is out? Think you need service? If you’ve checked the FAQs and can’t solve the problem, then check here and we’ll help you get the service and support you need as soon as possible.
    If you require service on your Plasma Television or Rear Projection Television, please call 1-800-237-4277 to locate the service center nearest you.
    Please call:
    1-87-SHARP-MWO (1-877-427-7696)
    for service information.
    I hope you will reconsider and accept and rate my solution accordingly as I strive to provide fast, economical, and accurate solutions.
    Thank you,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    Is there something about my solution you disagree with. If there is a better answer you are looking please let me know any maybe I can assist you further though you should have found my solution at least helpful as this will fix your problem therefore if you could accept and rate accordingly I would be quite proper and very appreciated.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 17, 2008
    sorry couple typo's
    better answer you are looking *for* please let me know any maybe I can assist
    accordingly *it* would be quite proper and very appreciated.
    Thanks,
    Lee
    Thanks for re-rating appropriately if any other issues with this problem come up please let me know.
    Thanks,
    lee
  • Lee A.
    Lee A. Sep 17, 2008
    I believe it is an inverter problem. You said the tv does turn on normally as well correct?
    Thanks,
    lee
  • Lee A.
    Lee A. Sep 17, 2008
    Usually it is inverter that is the culprit. Though I recommend having it diagnosed in person by a qualified professional. You also most likely can get an estimate from sharp.
    Thanks,
    Lee
Blinking lights on HP MD6580n
Sounds like the power supply is overheating.
Oct 05, 2012 | HP Md6580n 65 in. HDTV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Blinking Check Fan Light Message
sounds like the unit is truly unhappy, eh? the power board is most likely down de tubes, mon
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready LCD Television Logo
344 people viewed this question
Top Sharp Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
