Question about Sony KDF-E50A10 50 in. LCD HDTV
RED/PINK SCREEN W/BLACK SPLOTCHES
Could this be opticle block or light engine problem? Very frustrated! Is it worth fixing. This Sony is only 2-1/2 yrs. old.
  • 320 Answers
The only way to be sure is to have a tech evaluate it for a bad optical block
Posted on Oct 18, 2008
Pink splotches on white screen
I had a very similar problem with mine... You are correct, it is the optic block.. it will cost about a $1000 or so to fix. I chose to fix my 60" because I absolutely love these TVs. The Technology may be older but they are still great!!!!! (i.e. Instant Picture...no refresh rate required!!!)
If you think you also have a dust issue just get a vacuum cleaner and clean the vents on the back of your TV. You can also remove the Front Panel... take out the lamp (make sure your TV is COLD!!!...trust me on this) and vacuum what you can making sure you do not touch the back mirrors (located where your lamp goes in). You should do this every time you change the lamp at a minimum.
Nov 27, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Pink splotches all over the screen.
You may want to call sony customer service,this is a known problem and they had a warranty extension on the light engines of many models of LCD projection. A sony Auth service may guide you to a free repair if still covered!!
Jun 02, 2010 | Sony Televison & Video
What is the difference between a light engine and optical block?
Light Engine and Optics Block is same thing, main part of DLP TV and multimedia projector to produce and project image on front screen.
Few manufacturer call it light engine and some says it optics block.
Nov 09, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue/Yellow Splotches on screen
It will be 12 appliance years old in October. Not much justification for trying to repair it.
Mar 23, 2017 | Sony KDF-E50A10 50 in. LCD HDTV
I have a sony kdfe50a10 and the screen has been invaded by blue splotches. What's up?
The Light engine (also known as an optical block) which is essentially the projector part of your TV is failing and needs to be replaced. Sony has extended the warranty on some of its models so you can contact Sony to see if yours is still covered. If not it is outrageously expensive to fix easily over $1000.
rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
No blue colors projected on screen
Only a few causes for this problem. "Splotches" are usually caused by dust in the light engine which can sometimes be blown out using compressed air. Pink picture is caused by either data or burnt lcd card. Procedure for data is: put tv to ch. 3 and turn power off. simultaneously press input and power on set for three seconds to access service menu. Be very careful not to change settings other than what needs changed. These adjustments are changed using directional arrows. Navigate to "memory init" then hold (r) arrow button for 5 seconds. You will know if it worked. Then exit and/or turn set off. Please let me know if this is successful as I have additional info you may need. Good luck, Russmann.
Jun 09, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Different colors on the scanner screen
I didn't find a fix. I went to Best Buy and they said it would cost more than it was worth to fix. So I bought a new one. Thanks, mittenshadow
May 29, 2008 | HP ScanJet 5300C Flatbed Scanner
Light green and pink spots on my hd tv!!!
Tiny particles of dust on the light engine lens can cause this (and was a service call for me about a month ago), or possibly the expensive light engine.
May 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Colour distortion on tv screen
as you say pink& green means red+blue= pink &green means you are getting all color like b+g+r so it requires adjustment only please call skilled person to do it.
Oct 01, 2007 | Televison & Video
Sony KDF-E50A10 50 in. LCD HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
