Question about iLO LCT32HA36 Television
Ilo32hdtv remote butons do not work on remote and on the top of tv only on and off work
  • marr445 Sep 15, 2008
    ilo-technologie -32hd on the remote it has rc-370c on the box it has #bej62850448-3t4
  • iLO Master
  • 13,433 Answers
Try replacing the batteries, make sure any key is not stuck on the tv. Check if you have childlock turned on.
Posted on Sep 14, 2008
    Genius:
  • 1,011 Answers
Sir,
Plz provide Brand name and Model No.
thanks
My daewoo tv working on butons manualy but not on remote.'The remote is good.what can i do?
Hi Vasile,
If the remote is good then it is the TV which is not accepting your remote's command, there is nothing you can do about it yourself. Please consult some local TV Tech. By the way a simple test for your remote. Please press different keys on the remote and see the LED through your mobile phone's camera. You will see the LED flashing. If it does't happen, your remote is not working.
I hope it helps.
Good luck.
Aug 04, 2015 | Daewoo Televison & Video
HOW DO I MAKE THE ZOOM BUTON WORK
Try by set it with an other set-up code said for your TV brand. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search this Blog" window, and press Enter.
Nov 16, 2014 | Arris Remote Control
I need manufature codes for philips RC2034301/01 to progrma URC-8203
If you wish to get more codes and other details check:
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 19, 2014 | One For All URC-3021 Remote Control
How do you turn on the Closed Caption mode
U have the tv original remote wright?Yes?Look at the tv remote look for a button that said CC,press that CC buton a couple of times for it to have like CC1,2,3..if the tv program u are watching offer Closed Captioning u will have it.Or tries the tv manual button on the tv bazel frame itself that said Menu.Press the Menu buton go into the tv funsctions look for Closed Captioning funsctions in there look for it and turn it on all like CC1,2,3... all on will also getting Closed Captioning for the tv programmng shows that offer it too.
Aug 23, 2011 | Durabrand DWT1905 TV
The picture is too large for screen and is cut off on top and bottom. Possibly on the sides too.
There is a button the remote control that will resize images. However this could also indicate that a tv is in the wrong input and or connected to the set top box (ie cable box or satellite receiver) incorrectly. It can also indicate that the set top box is set to the wrong resolution.
Buttons on the remote control could be view mode, aspect or format, and # hd zoom.
The tv could be in the input for the rf connector or the composite cables instead of being on the input for the component or hdmi cables.
The tv could be connected to the set top box with RCA cables or a coax cable instead of being connected with component or an hdmi cable.
Apr 28, 2010 | Televison & Video
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
Remote not working, can not switch to aux/video..help
Normaly on the TV buttons thera are a buton named AV or sometimes with the Menu buton on the TV - if you have only Vol +- and Pr +- then you need a remote - sory
Sep 02, 2009 | Emerson EWF2703 27" TV
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
Centrex 80cm locked
there is a button on the remote that has a rectangle shape on it with a + inside the rectangle. Hold it down for 4 seconds or more.
Nov 04, 2007 | Televison & Video
Sony trinitron messed up
pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
iLO LCT32HA36 Television Logo
66 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Radames Pagan
Radames Pagan
loony2ns
Level 1 Expert
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
