Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore undercounter dishwasher quiet guard
I purchased the dishwasher in 2005. Have used it aprox 1 time week. Was working fine. One day I went to start it and no lights went on. I hear nothing, Power is fine. Any suggestions
  • 1 more comment
  • Anonymous Mar 19, 2014
    Was working fine. Went to use again and no lights on.
  • Anonymous Mar 28, 2014
    Do I need to push other than the start button to start dishwasher
  • Francisco Briseno
    Francisco Briseno Jul 15, 2014
    First check for power to the dishwasher, best to use a non-contact voltage sensor. Around $5 from Harbor Freight, or $80 for a Fluke brand. Once establishing your dishwasher has poser to it, check power with the non-contact voltage sensor on both sides of the Thermo-fuse. You can also use a voltmeter on both sides of the fuse, while touching any ground with the other meter probe. Check both sides and you should have power, or voltage, if you do not then the fuse is blown and will have to be replaced with a same and like rating or specification part replacement. If you have power on both sides of the fuse then your problem rests forward of the fuse, probably the circuit board. What I did was to replace the Thermo-fuse with a Push Button Thermal Circuit Breaker, 10A Item #: B7010. It has two 0.25 inch connectors that fit perfectly with the connectors attached to the burnt fuse. I purchased it for $3.99, but checking recently it is up to $4.39. The circuit breaker pops around once or twice every few months. I get to cleaning the inside of the dishwasher, the heater connectors and filters. I then press the reset button and away she goes for several months. The replacement Thermo-fuse calls for a $25 part kit that calls for cutting your old wires and splicing in the new ones. Keep in mind that it is a one shot deal, if it pops, you need to replace it with another $25 part kit. The reason the wires need to be cut is because the old female connector experience high current when the fuse blew and might have corrosion which is interpreted with resistance, which will cause a voltage drop thus current flow higher than normal and since current is heat POP! goes the fuse and not the weasel. I believe weasels are more than $25 these days. Another reason to cut-off the old plugs is that they may be loose and not snug, which will also cause higher resistance and the scenario repeats itself. Using thermo dynamics, Ohms and Joules with Watt's laws and $3.99 I was able to fix the problem and I hope I can help others as I have been helped in these sights. Word of advise, if you have power (voltage) on one side of the burnt fuse, DISCONNECT the house breaker feeding power to your dishwasher before you disconnect the burnt fuse and connect the replacement fuse, or a Push Button Thermal Circuit Breaker, 10A. And now for those with safety issue questions regarding deviating from manufacturer parts. The B7000 series circuit breakers are UL 1077 Recognized as Supplementary protectors, File E99607, and CSA Certified as appliance components protectors, File LR62590. I've had mine installed for a little over a year and has not popped more than five, I believe and since the house has not burned down, the specifications speak for themselves. Lastly, the breaker is rated for a life of 1,000 trips, so at 5 trips a year, it should be good till the year 2213, I think by then the dishwasher will be in a museum.
  • 3 Answers
Presuming that your circuit breaker is not tripped and you have power to the dishwasher, it appears that your thermo fuse is blown. You can replace it for around $20. It comes in a kit form or you can replace the thermo fuse for around $1. The part number is NTE 8096 Thermo Fuse 98 degrees Celsius and solder it in yourself. It is located on the circuit board that contains all the relays and the main computer chip. It clips on and off.
Posted on Sep 30, 2008
I see the pressure tower for a Kenmore Ultra Wash Quiet Guard dishwasher laying in the bottom of the dishwasher. I've just rented the house and haven't used the dishwasher yet. Does this pie
No, the designers put it in there for a reason; it won't work as well without it, as it would with it in. Probably the mounting tabs are broken or sprung. A new tower isn't very expensive. You can probably get one from SearsPartsDirect.com, RepairClinic.com, EasyApplianceParts.com, or AppliancePartsPros.com.
Mar 28, 2012 | Kenmore Dishwashers
I have a Kenmore quiet guard 3 model: 665.74364k2 and serie F55202295. It is not draining properly. It works fine and cleans the dishes but when it goes to drain it leaks in my basement ceiling and vents.
i thought I responded to this.
make sure the air gap in the kitchen plumbing (if installed is clear). Also check the kitchen drain is not blocked. If using garbage disposer in sink, then make sure it is run before you start the dishwasher.
Jan 10, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Dishwasher malfunction
The flashing light indicates that the control did not sense a 3 degree temperature rise with an 8 minute test. There are many reasons this could happen with a working heater. I put together a page that shows the reasons and you might be able to do about it and again how to reset the control so you can use it. Depending on how deep you want to dig into the issue or get a new one is up to you. I would weigh in how much you like the current machine overall against how much a new trouble free unit might be. The best one out there today in my book by far is the KitchenAid,
May 07, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore dishwasher does not wash completely
I had the same problem. I switched to a gel dishwashing liquid and added about 1/2 cup of white vinegar to each wash cycle. (Just pour the vinegar in a cup, put it in the dishwasher and let the water fill the cup and disperse the vinegar.) Gradually you can reduce the amount of vinegar that you use. Worked for me, hope it does the same for you.
Feb 07, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Dec 09, 2008 | Dishwashers
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Help
wow that could be a tough one there is no door lock on a dishwasher only a door latch what happens when you depress the door latch and can you send me a model number so i can pull up the blue prints and see if we can figure out a way to open it try pushing on the door and depressing the latch at the same time let me know what happens
Jan 10, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher
the water inlet valve is one of: 1.) electrically dead 2.) clogged with debris or: try this...unscrew the water inlet hose (after you turn off the water supply)...then clean the conical-shaped debris screen that you may find just at the entrance to the hose.
Jun 03, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
382 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
