Question about Mitsubishi VS-50605 50" Rear Projection Television
Mitsubishi VS 50605 no picture
TV purchased new (way back when) and rarely used. Push the power button on the face of the TV and the green light comes on (the light is located directly between the power button and the word "timer"). Absolutely nothing else happens. No picture, no nothing. I verified that the inbound signal exists by attaching it to another TV. Signal is fine.
Also, the remote is totally inoperative (whether this has anything to do with it or is another symptom/problem). New batteries makes no diff.
  • plshelp08 Oct 22, 2008
    Similar Problem. TV is connected to Antenna. Turn on Power button & sound can be heard, but No Picture. TV previously used with cable with previous owners, who probably never used it with an antenna before.
  • 1153 Answers
SOURCE: Mitsubishi VS-50605 - Colors separated
You have a convergence problem and need to reset
Posted on Nov 26, 2007
SOURCE: VS-50605
vertical sync- top of picture pulls to right on intermitently. Fly back?
Posted on Jan 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Vs-50605 TV dead
First thing on a Dead VZ7 to check is the solder connection at the yokes "DY" Connector. Then Check C411 2200uf @ 35V
Then C412 10uf @50V. Then Check IC700 Pin 20 for 0VDC any voltage other than 0VDC on that pin means Diode D980 is leaky.
Hope this helps. If you need anything further let me know.
Posted on Jan 26, 2008
icansolve
  • 45 Answers
SOURCE: Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Posted on Dec 18, 2008
SOURCE: Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Posted on Mar 29, 2010
I have a mitsubishi vs-50605 and when i turn it on the light comes on and clicks and the instantly clicks and shuts back off, I pushed the menu input buttons for five seconds and got one blink then two...
1,2 is no error detected---if during or before this you unplugged the set that clears the errors and you will get 1,2.
To confirm with set plugged in turn it on--when power light goes out repeat the self check.
May 15, 2012 | Mitsubishi VS-50605 50" Rear Projection...
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-5004R No Picture and No Audio
not enough power, you may need to rebuilt or replaced the power board
Mar 31, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitusbishi vs 5041
Good Day, rob;
More than likely you have CRT coolant (fuild) on the board(s). Check this by removing the TV's speaker grill, the small panel and look for the fluid using a bright light. It's not always easy to see, if fluid is found remove it with acetone and use heavy plastic and drape loosely over the board in the front. Always remove POWER from TV BEFORE ATTEMPTING ANY SERVICE. Good Luck, big IRISH.
Aug 17, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Tv wont come on
Check the horizontal output and regulator transistors. If you ould like the service manual let me know I can post a link where you can purchase it and have it emailedto you along with free help to elp you diagnose and repair your set.
Feb 19, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Nov 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
VS-50605 Screen
might measure the opening and buy a piece of plexiglass, wont look quite as good, but cheaper than a new one and usually available at glass shop.
Jul 06, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
