Question about Maytag MER6772 Gemini Electric Kitchen Range
Self cleaning gemini electric range with no maual
How does one use the self-cleaning feature. we cannot get it to work?
    Sergeant:
  • 409 Answers
can you tell me the complete model # please? i will look for the use and care guide.
thanks
Posted on Sep 26, 2008
My older model electric hotpoint selfcleaing range, lower oven self cleaning function is not working. what could be wrong, maybe i didn't set a control knob correctly, don't have a maual for t
Back to the fifties! If the lower oven cooks normally, the heating element probably is OK. For self cleaning the normal temperature setting is bypassed and the heating element is set to a substantially higher level. Your oven may be unable to self clean because operation of the knob may not actually start the cycle. The thermostat could need replacing even though normal cooking is OK.
Sep 02, 2012 | Hotpoint Kitchen Ranges
How to use self cleaning oven
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Apr 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
When ever I try to clean oven F-9 error comes up door won't lock. It worked a month ago
when I used my self clean feature it got so hot that it burned out the sensor and I got the same symptoms you are describing.The sensor is inside the oven behind a two screw plate. take the plate off and un-plug the sensor and replace
Mar 16, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Just want to know how to set the self clean feature on a Maytag gemini double oven range
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jul 16, 2010 | Maytag Gemini 30" Self-Cleaning...
Lost manual for self cleaninf Maytag oven. It's about 8-10 years old.
My answer is to NOT use that feature, as generally after most people use that :Feature" straight after the oven faults, you see that "Cleaning" mode simply heats the oven up wayyy up to like 900 degrees up, and after this the temperature sensors generally "Go" so my advice is ... use elbow grease and save a lot of possible problems, especially with a 8 - 10 yo unit.
Mar 16, 2010 | Maytag Gemini 30" Self-Cleaning...
I get an error message F9-4 when I try to use the self-cleaning feature.
check for obstruction in the door closeing latch/switch
f9-4 on a maytag means i cant close/lock door
Jan 29, 2010 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag electric double oven range MER6775. I need the instructions to run the self cleaning feature for the ovens.
FIRST REMOVE THE RACKS.PUSH CLEAN THEN AUTO SET T. PUSHING AUTO SET EACH TIME MOVES IT TO LIGHT MED HEAVY.
Jan 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Lost my manual. how do i clean my self cleaning Gemini double ovens
would need the model #, but generally, the top oven is manual clean. To clean larger oven, press clean, then up or down next to the timer to determine how long you want the self clean to run.
Nov 15, 2009 | Maytag Gemini 30" Self-Cleaning...
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
Dec 18, 2007 | Maytag MER6872BAS Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
55 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
