Question about Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60 XBR1
Won't Power on Green light is keep blinking
  • Anonymous Jan 30, 2009
    tv just wont turn on and the green light keeps flashin
  • outes_82 Feb 10, 2009
    I have the same problem and I think that maybe the best solution is to join the lawsuit against sony because it is not fair that we spent a lot of money for our tv's and now we have to deal with a lot of problems
    http://www.breakitdownblog.com/class-act...
I've heard thiis is a fan issue that you need to replace an exhaust fan which is pretty cheap
Posted on Nov 07, 2008
Sony kds-50a2000 picture blacks out and green light blinks
Either the lamp is on it's way out or..... the lamp is incompatible because it is not a original one. (ie the same as what they fit in the sony factory)
Nov 06, 2013 | Sony KDS-50A2000 50" HDTV
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
Three red blinking lights
I would first always check the lamp to make sure that its not burnt out. On my 50 XBR1 the lamp door is on the right side of the tv. But here is the code for three blinks of the light,
3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
Hope this helps.
Jun 29, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony SXRD KDS-50A2000 Will not power on. Green
I have the same problem with my unit. I've been removing the bulb and just replace it back and unit will work again. I probably need to vacuum or check the fan out too.
Mar 09, 2010 | Sony KDS-50A2000 50" HDTV
6 red blinking lights
You have a bad thermal fuse.
Oct 23, 2009 | Televison & Video
TV not working after replacing lamp
yes, the door has to engage a switch and if it doesn't the tv will not come on it usually has a 3 blink error if this is the problem. Is your red light flashing in a 3 blink series?
Sep 16, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
3 year old Sony KDS R50XBR1 suddenly no picture, no sound
MY SONY KDS-R50XDR1 TV ITS PLAYIN GREEN THERES NO BLUE HOW CAN I SOLVE THIS PROBLEM.
Feb 10, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
784 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
