Question about Yamaha HTR-5550 Receiver
Volume control on unit
The Volume control on my Yamaha HTR-5550 no longer works (actually tends to turn the volume up no matter which way you turn it. Control from the remote is fine, but there are times when it would be handy to just reach out and turn it down with the knob.
Any simple solutions?
Thanks Kent
  • 1 more comment
  • Anonymous Nov 28, 2008
    The volume control on mine is broken too, where do you get the part?
  • Anonymous Mar 14, 2014
    Remote works fine but volume control has to be done manually. Is it the tuner volume control or the remote?
    Does the remote increase volume control need to be replaced? Volume control works when done manually. Is there a motor that controls the volume control?
  • 31 Answers
Kent, Unfortunately, it sounds as if the encoder is broken. The encoder is a digital input which takes the place of a traditional volume control, and is what holds the volume knob in place and spins. Since it works fine with the remote, that means everything else is ok, but you will have to replace, or have a tech replace, the encoder itself.
Posted on Sep 16, 2008
My Yamaha HTR 6130 surround sound amp just froze up on me and won't turn off or on or control the volume ect. I'ts on but will not do anything, I can't control from remote or the unit itself at all.
HI
i think the unit needs to be set back to factory defaults
procedure is
Initializing the HTR 6130
1. Connect the power cable of this unit to the AC outlet.
2. Press the "STANDBY/ON" key while simultaneously pressing the "STRAIGHT" and "AUDIO SELECT" keys.
The self-diagnostic function is activated.
3. Select the main menu "13. FACTORY PRESET".
4. Select the "PRESET RSRV".
Hope this helps
Kind regards.
M.Mathis
Apr 14, 2016 | Yamaha Htr-6130bl 500 Watt 5.1-channel...
I have a yamaha "htr-5630"
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume, for all intents and purposes it's not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Mar 07, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
We have to hold the remote control button hard and straight at the reciever for ti to work
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
May 20, 2010 | Yamaha HTR-5860 Receiver
The shaft of the volume control was contaminated with crazy-glue
3. Type 993
Jun 07, 2010 | Yamaha HTR-5740 Receiver
The volume control knob fell off can i buy a new one model htr 5860 yamaha
Sometimes volume controls are held on by an Allen type screw, which can become loose, allowing it to fall off. You should see a hole in the knob if it is. You might need a long thin Allen Key to get it back on.
Otherwise have checked my spares guide (though it's a few years old) and it seems Yamaha might only do their own spares.
Feb 12, 2010 | Yamaha HTR-5860 Receiver
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
Comcast remote
3. Type 993
Jul 05, 2008 | Yamaha RX-V1400 Receiver
HTR-5550 will not stay on.
jerry ...
question??? before you stored the unit, was it working fine?
are you using the same sets of speakers like before?
Mar 15, 2008 | Yamaha HTR-5550 Receiver
Yamaha HTR-5550 Receiver Logo
434 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
