Question about LG WM-2277HW Front Load Washer
TROMM LG WM-2277HW
Machine beeps and shows dE. Door locked blinks. All settings do this.
  • ksmith588 Sep 29, 2008
    ON OUR LG FRONT LOADER THE DOOR SEEMS NOT TO CLOSE SMOOTHLY FROM THE HINGE SIDE. I CHECKED FOR GRIME BUILD UP OR SOMETHING STUCK, BUT I DIDN'T SEE ANYTHING. AS A RESULT YOU GET A "DE" ERROR CODE. IF YOU FORCE THE DOOR SEVERAL TIMES IT WILL CLOSE. THE SWITCH LOOKS FINE
  • 489 Answers
You may have a broken door latch switch that doesn't tell the computer that the door is actually closed.  Before you actually replace the latch switch, make sure the wire connectors are securely attached to the latch assembly.
Posted on Sep 29, 2008
Code dE
Check the door latch assembly switch for continuity, replace if faulty.
Feb 22, 2014 | LG WM-2277HW Front Load Washer
DE error code on LG washing machine
Beyond that could just be the door latch itself.
Nov 23, 2013 | LG WM-2277HW Front Load Washer
Hi, when the programs are set and then when you press start dE apears and the machine will not start
'dE' stands for 'door Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 14, 2011 | LG WM-2277HW Front Load Washer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
I have LG ,Tromm washer machine front load have problem. Door is not closing completely .
The "dE" error code indicates that the LG Tromm washer's door has not been properly closed. Closing the door firmly usually clears this error. If the error does not go away once the doors closed, a service technician should be consulted.
Jun 03, 2011 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Lg tromm wm2277hw code de
Error Code "de" is for "door switch assembly faulty".
You can down load the service manual from this site:
http://136.166.4.200/contents/Laundry/WM2277.htm
Have fun!
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
715 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
