Question about Panasonic AG-DVX100A Mini DV Digital Camcorder
Tapes won't Playback in other deivice
Ever since I purchased my Panasonic dvx100a tapes recorded with it playback fine on the camera, but will not playback on other playback devices. There is no sound and the video is doistorted or only a blue screen. The other device does pick up the timecode, however.
  • 126 Answers
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
Posted on Feb 02, 2010
Cant playback tape
Videos recorded on one camcorder very seldom play back in another, due to the internal codes put on the tape by the original machine.
Aug 09, 2017 | Panasonic NV-GX7B Mini DV Digital...
I own a Panasonic 3ccd nvgs mini dv i was shooting some footage...tape got horizontal lines on it... i really really need that tape... can it be fixed?...thx a milion
Sounds like dirty heads .
If the lines are recorded onto the tape, probaly not.
Try a head cleaning tape in the camera or use another playback device.
If the lines are recorded onto the tape then track down someone with a TBC (timebase corrector) and pipe the signal through that and record to another tape.
Apr 13, 2011 | Panasonic NVGS-200 DV Camcorder 3 CCD 2.32...
Where can I purchase a head cleaning tape for a DVX100A camera?
Screen? Had the same problem. It's an internal flex wire connecting LCD with camcorder. Got from the repair shop did it by miself and it's like knew. It's very common in sony. Good luck
Sep 28, 2009 | Panasonic AG-DVX100A Mini DV Digital...
My Panasonic DVX100A is not recognizing the tape what could be the problem?
most likely problem is dirty video heads. try a Panasonic cleaning tape; if that doesn't work, hand cleaning by a technician should work.
Jul 27, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Distorted sound on playback, samsung mini dv camcorder.
Try a DV tape cleaner first. If that doesn't work, see what it would take to get the audio heads realigned. Any camera store can do that for you.
Dec 18, 2008 | Samsung SC-D67 Mini DV Digital Camcorder
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
No record or playback
had the same problem, it seems to do fine without a tape in it :so I took the tape in and out a few times and I guess the alighnment was better so it works for Now..So Give it a try
Dec 12, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
DVX100A panasonic camera tape mechanism not working
You can open the cassette cover and spray inside the upper left side of mechanism(closer to the back) with contact cleaner spray,because there is a rec inhibit switch.If it's not damaged and just dirty you solve your problem ,but if is damaged it needs replacement.
Jul 26, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
325 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
