Question about HP Pavilion dv6000z Notebook
ZV500 power plug problem
I had the power plug replaced, but the laptop still doesn't power up: the 3 second lighting bolt LED indicator thing, and then nothing. So now my options are either repair the system board, or replace it. I'd like to try to repair it myself, but I don't have a schematic. Do you have any suggestions? Thanks.
  • shams79 Sep 17, 2009
    my laptop acer 5220 when I start the system by power Button automatically after about thirty seconds off the system
    Scholar:
  • 60 Answers
I've repaired alot of laptops... One thing that I found works the best is get 3 bowls or dishes.... Label them; 'Top', 'Bottom', and 'Logic'. Almost all laptops require you start disassembly at the base of the unit. Unscrew every single screw you see, make sure there are none left before you start on the top. The way alot of laptops are set up is that you unscrew the bottom, pop off the top casings/covers then unscrew the top screws. Once you've removed all the screws from the top and the bottom, there will be very little attaching the casings, so be careful. Remember to Unplug everything you see attached to the logic(mother) board, or you risk ripping a fixture off the board. Once you have freed the logic(mother) board from the attachments and casings you should very careful.
Now as you start work on the power jack, I Highly recommend you use a solder wick and flux to remove any solder left on the board from the previous repair. It is never a good idea to leave old solder on the board. You should be careful with the solder you don't want to short anything out by using to much solder. Once you have finished your repairs to the DC jack you should test it out plug it in to the AC Adapter and look for any visual indicators of life(i.e. charge batt light).... So now you know it works.
If you get it back together and it suddenly doesn't work its possible you have a case short. If thats the case look on the metal casing for any discolorations or blackness and if you find any place some electrical tape over it... it should be fine.
Good Luck. Don't be nervous its not as hard as it seems.
Hope this helps lemme know if you have any questions.
Posted on Sep 17, 2008
Presario R4000 battery is charging but the lightning bolt is not lit
When you first turn on the laptop, does the lightning bolt LED light up for a split second, even before Windows opens? That is a test that the LED is not burned out. If it does, then are you using the correct AC adapter that came with the laptop? Some look identical, but are not as powerful enough to run the computer correctly and you wouldn't necessarily notice a difference except something like the LED. How old it the battery and how long does it take to fully charge?
1. Reset the laptop by shutting down the laptop and unplugging from AC power;
2. Remove the battery;
3. With the computer unplugged and no battery, hold down the power button for 30 seconds. Remember no power on the computer at all for this step.
4. Replace the battery and plug it back in and turn on.
If that doesn't help, search the internet or HP's web site and update the BIOS for your specific system. Look for good directions for doing this and don't run the BIOS update from the internet, you should download the BIOS to your computer and then run it from there. The BIOS cannot be interrupted. If the BIOS is interrupted while installing, it WILL render your computer useless and you will have to replace the motherboard (extremely expensive).
Jun 12, 2014 | Compaq Presario Notebook
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
The adapter stopped charging my laptop due to a faulty wire, I bought a new adapter and now as soon as I plug in it starts for a second and turns back off. The charging light blink and it doesn't
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 28, 2013 | HP Compaq Presario C509NR Notebook
My Notebook all of sudden doesn't power on.
I find that many times when a laptop won't power on either on batty or plugged in, the thing to try is to unplug it, then taske the battery out for about a minute and then put the battery back in and try again.
Dec 13, 2012 | Toshiba Satellite L755-s5248 15.6" Laptop...
Suddenly won't turn on no charge light indicator
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's power socket.If the power/battery LED light flashes and in a certain position this LED lightstays firm, then the power socket is either faulty or it has a dry solder jointwhere it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 25, 2012 | ASUS G71G-A2 PC Notebook
Dell inspiron 6000 dead when connect power adeptor to laptop the led light on psu goes off is this mother board fault or psu.
If the led on the power supply turns off after connecting it to your laptop, the problem most likely lies with the power supply especially if the machine will run on battery power. This can be tested by
1. Turn the laptop off.
2. Remove the battery and power supply plug.
3. Press and hold the power button for at least 15 seconds to reset the laptop.
4. Replace the power supply plug into the laptop without replacing the battery.
5. If the computer will not start and there are no lights turning on on the laptop the power supply is bad.
6. Replace the battery and attempt to start the machine both with and without the power supply plugged in.
Apr 04, 2011 | Dell Inspiron 6000 Notebook
Basically i plugged in the ac adapter to it, pressed the power button and the power light comes on for 2-3 seconds then the power light shuts off. lcd screen never turned on or show anything, fan never...
>>> Please leave feedback so I can continue helping You & Others
The middle blue led is the charging indicator, sounds like you have (at least) a bad battery, remove it, plug in AC and try again, if no good, remove the HD and repeat, if no good, remove/replace the ram and repeat, if still no good, your mainboard is cooked.
Thanks,
Adam.
Feb 19, 2011 | HP Pavilion DV9429US Notebook
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
Put in a branbd new battery. Power adapter is OK.
Your motherboard does not need replacing provided the problem is the power socket on the motherboard.
If the power adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Nov 15, 2009 | Compaq Presario 3045US Notebook
HP Pavilion dv6000z Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
