Question about Phase Linear PCR4500CS
Remove radio from dash
I would like to know how to take this radio out of my dash?I want to replace it with a cd player
    Scholar:
  • 123 Answers
What kind of vehicle are you attempting to remove the CD player out of?
Posted on Sep 14, 2008
Trying to replace a radio in an Nissan Almera n16 (2003), I Is it possible to replace this radio, or because the dash radio/Air-con is all the one?
Look at the bezel around the radio. It just pops off. If it goes up around the instrument panel, look for screws around there. Under the bezel, there will be screws to remove.
Sep 07, 2015 | Nissan Cars & Trucks
I am getting an error read on my CD player. The CD Disc CD player (original) to my 2003 Experdition will not release CDs. The CD player which is an automatic feed was force fed a CD by a minor child. The...
The unit can be removed but disassembly will be required to remove the OFFENDING CD. Even at that, the player mechanism may have been damaged so that CDs simply cannot be played at all
Jan 28, 2013 | OEM 2002-2004 Ford Focus Factory AM/FM...
My 2003 Lincoln Aviatro CD player does't work . I would like to know how to remove it from the Dash?
I believe the entire unit is 1 piece. There should be 4 square holes in the face of the radio. Walmart sells the clips which go into this radio and you need them to remove it.
Jan 27, 2012 | Car Audio & Video
Replaced the battery & now the radio/cd player
Your radio will need a code to reactive it because the power has been lost.
You need to post up the serial and part number of the radio - found on a label at the back so you will need to remove the radio from the dash to find this.
Make and model of radio and car also required. Then we can advise further.
Thanks for using fixYa.
Aug 26, 2011 | Car Audio & Video
My cd player will not accept cd's (the tray inside will not come down) so I think I'll have to buy one from a salvage car - Question is (1)any thoughts on fixing the existing cd (2) how would I go about...
REMOVE THE RADIO FUSE FOR ABOUT 30 SECONDS THIS MAY RESET THE RADIO/CD PLAYER.
IF YOU DO INSTALL ANOTHER RADIO IT WILL HAVE TO BE PROGRAMMED AT A DEALER.
REMOVE THE COVERS ON THE SIDES OF THE DASH.
REMOVE THE GLOVE BOX ASSEMBLY.
REMOVE THE KNEE BOLSTER UNDER THE STEERING COLUMN.
PUT ON THE PARK BRAKE AND SHIFT THE CAR INTO NEUTRAL.
REMOVE THE BEZEL AROUND THE RADIO, CHECK THE LOWER CORNERS FOR SCREWS, PULL OUT CAREFULLY ON THE BEZEL.
REMOVE THE RADIO.
Jul 12, 2009 | 2006 Pontiac G6
Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
Jun 10, 2009 | 2004 Chevrolet Malibu
Need to replace the radio/cd player in my 2001 elantra
on the hyundai you will usaually see four small holes two either side of the radio unit itself. if you take 4 allen keys/hex keys and insert all at the same time making sure to keep them very straight the stereo unit shuld then be free to pull out. you will then find that it has a universal plug on the back of it and you should be able to plug and play with that. if wrong size/type of plug then buy a convertor from motor discount store.
Feb 25, 2009 | 2001 Hyundai Elantra
Want to replace factory radio
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Dec 04, 2008 | 1995 Oldsmobile Eighty Eight
Cd player
remove ash tray one screw behind there, then remove top dash panel that goes from end to end across dash this just snaps off pull upward to remove you will see 2 screws on top of trim around radio remove these 2 and then dash trim will pull off pull straight back then radio can be removed should be held in by 2 10mm bolts, this should cover 80% of the radios (important TIP) if it still doesn't come out the trick is some of the wranglers have an extra security bar on stock cd players only you will see 2 more 10mm bolt on the top of the dash where you removed the 2 screws from earlier these hold a bracket that is mounted to the back of the cd player once they are unbolted you can remove the radio it takes some pulling and tweaking of the brackets but it will come out
Jun 12, 2008 | 2002 Jeep Wrangler
Phase Linear PCR4500CS Logo
146 people viewed this question
Top Phase Linear Car Audio & Video Experts
Lyle Siemens
Lyle Siemens
Jaime Hernandez
The Audio Lab
Are you a Phase Linear Car Audio and Video Expert? Answer questions, earn points and help others
