Question about Cuisinart CSB-77 SmartStick Blender
Cuisinart CSB-77 handheld blender - whisk and chopper/grinder don't turn
After only a few uses, the whisk and chopper/grinder have stopped working, while the blender is fine.
It looks like there is supposed to be a friction connection between the wotor unit and the driven unit, but it no longer fully connects ( like a slipping clutch, the motor runs freely, but doesn't engage).
Is there a quick fix for this and is this a common problem?
Thanks.
  • 2 more comments
  • chinggis Sep 14, 2008
    sorry for the typo - 'wotor' was supposed to be 'motor', of course.
  • Anonymous Dec 02, 2008
    I have the same problem.
  • Anonymous Dec 23, 2008
    Same problem
  • quixotickate Feb 09, 2009
    Same problem, but with the blender and the chopper/grinder- the whisk is fine.
SOURCE: cuisinart bc56 blender
I cannot find the part of the rotator that goes on the blender. the cuisinart parts only have the one that goes into the jar
Posted on May 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: clutch on the jar of my cbt500 cuisinart blender is broken.
The clutch assembly is for the teeth on the base itself. If your problem is with the teeth that are connected to the bottom of the blade that sits in the jar, you want to order a blade assembly instead.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Mar 22, 2009
SOURCE: parts for cuisinart blender trio model bc-56
GO TO:
http://www.smallappliance.com/department.asp?cur=USD&sid=18954&mid=8&shopBy=Brand&cam=cuisinart_parts&gclid=CJTy7Om5qZoCFRk_awod9Gjw1Q
FOR CREDITS MAIL BACK TO: NEFIUINC@MSN.COM
Posted on May 07, 2009
co7196
  • 3433 Answers
SOURCE: the lights on my cuisinart blender come on but the
Using your blade holder, turn the motor from the blade end. 1 or two turns. Tak the blade holder out, Plug in an test Sometimes the brushes in the mototor lose a good contact. SGood Luck -Ned-
Posted on Sep 19, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: connection between the motor and the blender unit
Replace the blade assembly immediately. They are available from Cuisinart's website. Sugars and other stuff can gum up the blade assembly over time, so it will periodically need to be replaced. A quick and easy way to keep the blade assembly clean and working longer is to put water and a drop of dishwashing soap in the blender after use and run the blender at low speed for 15-20 seconds - an old Osterizer trick.
Posted on Sep 29, 2009
Attachment stuck
try to rotate top part while you pushed it down with two hands, somme one must help you to handle basement with forces in oposite direction, work smoth dont give too much force in the samme time or you are going to broken top part, put force in ascending
May 10, 2014 | Cuisinart CSB-77 SmartStick Blender
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
My model csb 77 hit a bone and a plastic part in the motor assembly broke. Can I get it repaired? Can I take it apart and do it myself? Pete
No solution acording to the company. They do not sale this part..You'll have to buy the whole motor for 25$. I think they do that part on purpose to make you buy more. I have the same problem.
Jun 15, 2011 | Cuisinart CSB-77 SmartStick Blender
Blades not turning, motor spurtering
I would say that these high speed motors are prone to wearing out their brushes quite quickly, but are not really designed to come apart.
I suppose it is their mode of failure.
If you can find spare brushes for the motor, then do, but the unit is likely to be clipped and solvent welded together, so may be cracked during repair.
Feb 20, 2010 | Cuisinart CSB-77 SmartStick Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
The handheld blender makes a horrible screeching noise all the time. I don't see anywhere to lubricate it or even take it apart. What's a person to do?
Time to use your warranty or throw it out. Not a serviceable product, you can't order a set of bearings for this. sorry
Aug 06, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Where can buy spare parts
I need a new blade aftermarket
Sep 27, 2008 | Philips HR1358 Handheld Blender
Blenders Logo
101 people viewed this question
Top Cuisinart Blenders Experts
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
