Question about Canon PIXMA MP600 all-In-One InkJet Printer
Poor color printing
Several weeks ago I encountered the problem that others described regarding the cyan cartridge not being recognized. After installing two different new cyan cartridges, it now recognizes that I have a full cartridge in that slot.
However, I cannot print a color document. Black and white documents print fine. Instead of solid blocks of color I get stripes of color alternating with white for all three ink colors. I've tried running the clean nozzles and the deep cleaning using the printer utility (I use a Mac) to no avail.
  • percolate Sep 14, 2008
    Sorry to sound stupid, but how do I remove the print head to soak it?
    Sounds like I'm going to need a technician-the bands of color are very regular.
    Thanks for the information on how to remove the printhead-I'll try that tonight and if it doesn't help, then I'll see about getting the printer repaired.
    President:
  • 1,952 Answers
MP600 Easy fix for unrecognized ink cartridge The PIXMA MP600 can print or copy up to 30 ppm in black and up to 24 ppm in color, and a 4" x 6" borderless print takes about 28 seconds. The USB 2.0 Hi-Speed interface enables the fastest image transfers and scanning speeds possible today. Plus, with direct photo printing, just connect to any PictBridge compatible digital camera or DV camcorder, a ...[More]nd print. You can even download images directly off of CompactFlash, Micro Drive, SmartMedia, Memory Stick, Memory Stick Pro, SD and MultiMedia Cards. It's IrDA interface provides wireles capabilities as well. Plus, the MP600's Easy-Scroll Wheel makes operation so much easier, and the 2.5" TFT display lets you preview images in high definition before printing.The unit's 5-color ink system - four dye-based inks plus a pigment-based black ink - produces exceptional photos, along with laser-quality text. Canon Full-photolithography Inkjet Nozzle Engineering (FINE) uses a high-performance 3,584-nozzle print head that ejects precise and consistent. With that, you get outstanding resolutions up to 9600 x 2400 color dpi and clear, detailed images. When scanning photos, you'll produce brilliant 2400 x 4800 dpi scans with intense 48-bit color depth. Its copier reduces and enlarges between 25 and 400 percent, while featuring Borderless, AE (Auto Exposure), 4 on 1, 2 on 1, Fit-to-Page, Image Repeat, Auto Magnification, Fading Correction, Multiple Copy: 1-99 pages, Face Brightener and Dual Color Gamut Processing technology. To further increase productivity, the MP600's built-in 2 sided printing saves time and paper.
[Hide]
Posted on Sep 14, 2008
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
  • Canon Master
  • 1,879 Answers
How about a standalone copy ? does it have the same output ?
  • Canon Master
  • 19,396 Answers
It means that the printer is not spraying properly all colors.
If the bar are regular, that means that the printhead is blocking the spry at regular times intervals.
Sometimes this problems is related to the printhead.
You find out if it is a faulty printhead by removing it, leaving in in isopropyl alcohol overnight or replacing it.
If printhead is fine then it is a problem with the control board.
  • Ginko
    Ginko Sep 14, 2008
    On many Pixma model there is a small lever to the right of the ink carriage, often it is grey in color, that will unlock the printhead.
    Once you free it.
    If the problem is with the printhead, the wrong color sprayed will be irregular. If you get very regular color bands, it is more likely the control board.
    If you get vertical bands with no color , then can also be the traction system (motor traction belt).
    The printhead is the only fault that is easy to fix at user level, the rest will need a technician.
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Why does the 2550n printer not printing fully in the left column
Is the print quality poor on left side for all colors? You may have one bad cartridge. Create a paint document with Yellow, Magenta and Cyan squares on the left side and see if one color prints better than the others. You can also gently shake the cartridges to redistribute toner.
Sep 08, 2014 | HP Color LaserJet 2550n printer + HP Color...
Hp c6180 states cartridges missing or damaged
OK now this might seem bizarre, but did you go ahead and click the "Black Only" print option?
I have a C6180. Just installed all new cartridges. Tried to print and got the message that Cyan is empty. Tried all sorts of things. Then out of frustration clicked the Black Onl option. Document came out printed in color! Double checked with a picture that has lots of cyan colors. It all printed too! Go figure.
Apr 25, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP 4700 not printing cyan
If your printer is missing a color it could be caused by (off the top of my head) 3 possibilities.
1. High voltage board
2. laser/scanner assembly for that color
3. DC controller might need a firmware upgrade, www.hp.com
Run the PQ diagnostics, check the cyan color
Run the Cartridge Disable diagnostic. Remove all cartridges and take the black cartridge and insert it where the cyan normally is. If the black prints in the cyan slot, your cyan cartridges are bad. If the black doesn't work then go to #3 above. It won't cost any money to upgrade the firmware. If it still doesn't work call in a printer tech.
At this point you may need a printer tech.
Nov 01, 2011 | HP LaserJet 4700 Printer
My HPLJ3500 Color Printer wont print black even tho we just put in a new cartridge. Prints magenta, cyan, yellow, but no black. HELP!
Run the PQ troubleshooting diagnostic.
See if the black is printing.
If not, run the Disable Cartridge check. This will allow you print with only one cartridge in the printer. Take out all the cartridges. Put the black in another slot and put the cyan in the black slot(the top). Print the config page. If the black is printing, is the cyan printing. If black isn't printing the cartridge is bad. If black is printing and cyan isn't something is wrong with the printer. If they are both printing put them back in the correct locations along with the other two colors. It isn't the printer.
Jan 11, 2011 | HP Color Laserjet 3550 Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Horrible ink issues..
Unless you are printing a lot in that color, my Epson Stylus photo color R300 uses black at about twice the rate as the color ones. Most packages or ink, I find, also come with two black and one of every color. All my color ones seem to emply at approximately the same time as the others.
Mar 08, 2009 | Epson Stylus CX9400 Photo Printer
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
HP Deskjet F2100 All-in-one has two slots for printer cartidges. Which of these two slots is meant for photo cartidge?
The photo cartridge replaces the black cartridge. It is used along with the color cartridge to provide better photo's.
The photo cartridge contains photo black, light cyan and light magenta while the color cartridge provides cyan, magenta and yellow. Both photo and color cartridges need to be installed and working for proper photo printing.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Jun 19, 2008 | HP Office Equipment & Supplies
Ink Cartridge Error PIXMA MP830.
pleaz clean the cartridge sensor and also align cartridges by program in your manual
Sep 09, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
217 people viewed this question
old marine
old marine
Corne Viljoen
