Question about PfaFF Sewing Machines
Needle keeps falling out of Pfaff Creativ 2170
I use this machine for embroidery and recently the needles have been falling out of their holder. I insert the needle the correct way and tighten the screw but within a couple of minutes the needle comes out and I find the tightening screw has become loose. The machine maks a clicking noise just before the needle comes loose.
I presume something has worn on the machine. Is this a common problem? How can it be fixed? If it's a simple solution as I'd like to deal with it myself. It took Pfaff a month to deal with a relatively minor problem last time.
  • rhiannon17 Sep 15, 2008
    THanks I'll check it and get back if I need more help
  • 19,396 Answers
Check that the metal plate under the needle is properly fixed into the machine.
If the needle is hittling the plate, it can get stuck and fall out.
If the needle keeps getting out then the small pin that keep the needle is broken, you will need to take apart the machine to fix this.
Posted on Sep 14, 2008
    President:
  • 1,952 Answers
Change ur needle bar and also check needle size before insert in it.
  • mohammed marika thambi
    mohammed marika thambi Sep 14, 2008
    1. A sewing machine comprising a needle bar having a lower end; a
    needle for carrying an upper thread and attached to said lower end of
    said needle bar; a vertical shaft; a needle bar support swingable
    around said vertical shaft to swing said needle laterally with respect
    to a fabric feeding direction, an upper drive shaft operatively
    connected with said needle bar and rotatable to vertically reciprocate
    said needle bar on said needle bar support; a loop taker for carrying a
    lower thread and operatively connected with said upper drive shaft for
    rotation in synchronism with said needle, said loop taker and said
    needle cooperating to interlock the upper thread and the lower thread
    to form a stitch each time said needle is displaced downward; a thread
    take-up lever operatively connected to said upper drive shaft for
    vertical reciprocation in synchronism with said needle to feed the
    upper thread to said needle upon downward movement of said take-up
    lever and to tighten the stitch upon upward movement of said take-up
    lever; thread deflecting means arranged between said thread take-up
    lever and said needle for deflecting the upper thread laterally of the
    fabric feeding direction in response to swinging movement of said
    needle bar effected in response to selection of zigzag stitch pattern
    data stored in a memory of said sewing machine; thread blocking means
    arranged on one side of said thread deflecting means and movable
    relative to said thread deflecting means between inoperative and
    operative positions; and actuating means for moving said thread
    blocking means to the operative position of said blocking means in
    response to selection of the zigzag stitch pattern data, said thread
    blocking means in the operative position thereof blocking the upper
    thread as the upper thread is being deflected in one direction by said
    thread deflecting means for providing a predetermined degree of tension
    of the upper thread to thereby tighten the stitch on one side of the
    zigzag stitch in addition to tightening the stitch by said thread
    take-up lever.
    2. A sewing machine as set forth in claim 1, wherein said thread
    deflecting means includes an arm having an end rotatbly supported on
    said vertical shaft and operatively connected to said needle bar biased
    by a spring arranged between said needle bar support and said arm.
    3. A sewing machine as set forth in claim 1, wherein said thread
    blocking means includes a member having a limb movable toward said
    thread deflecting means when said thread deflecting means is in
    operative position thereof, and away from said thread deflecting means
    when said thread deflecting means is in inoperative position thereof,
    said limb blocking the upper thread upon deflection of the upper thread
    in the one direction by said thread deflecting means.
    4. A sewing machine as set forth in claim 1, wherein said actuating
    means includes a solenoid which is energized for moving said thread
    blocking means to the inoperative position of said thread blocking
    means and is deenergized for moving said thread blocking means to the
    operative position of said thread blocking means
Can you bud a new needle holder for the pfaff hobby lock serger?
you probably need to contact a pfaff dealer that has a sewing machine repair technican, to see if they can get the part.
Apr 30, 2014 | PfaFF Sewing Machines
the best thing would be to take the machine to a sewing machine shop & have them check to see what's wrong with the needle holder, cause if there's a something broken it will have to be replaced
May 29, 2012 | Singer 7444 Mechanical Sewing Machine
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
Hello, hope you can help me. I have a Pfaff 7570 embroidery machine and was doing a pattern when it jammed. I noticed that the needle now hits the outer shuttle race. I think the timing is out. Can it be...
Did you change the needle to a new one out of a package? Also make sure that the needle is inserted to the top of its holder, press up hard when you change it. No luck? Maybe its knocked out of time...then its going to need to see a pro.
Derek
Jan 17, 2011 | PfaFF Creative 7570
Pfaff 2170 - during embroidery, the nylon thread gets all shredded up in the machine before getting to the needle and needle thread feeder and breaks. No problem when using the heavier weight threads like...
Nylon thread is difficult to use as a top thread. When taking a special class, we set the spool on the table behind the machine with a thread net over it. A safety pin or paper clip was taped to the top of the machine like a thread guide before running the thread through the tension mechanism. For the most part, a lot of instructors will advise using nylon thread in the bobbin but not as a top thread,.
Dec 23, 2017 | PfaFF Sewing Machines
I have acquired a pfaff 463-34/01 machine and require needles bobbins bobbine holder/s and a handbook Can you help? Regards peterjjohn@tiscali.co.uk Tel 01829 270931
i have bought a pfaff 463 machine and when i sew the thread going through the needle keeps on shreading..... any suggestions
Feb 08, 2010 | PfaFF Sewing Machines
Needle hits the bobbin holder and doesn't grab the bobbin thread
Check you have the right size bobbin case the gap where the needle enters should be 13mm approx at the widest point. A lot of other pfaff bobbin cases seem to fit and can be easily be mistaken. I have two pfaffs and have accidentally mixed the cases and had a similar problem.
Mar 04, 2009 | PfaFF Creative 7570
Sewing design thread breackage
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 01, 2009 | PfaFF Creative 7570
Pfaff Select 1540
Search for:
sewing machine timing
Lots of web sites and videos available.
Jun 28, 2017 | PfaFF Hobby 4260
Sewing Machines Logo
347 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
