Question about Dell Inspiron 1501 Notebook
My dell laptop is not turning on with the ac or battery. The LED lights up for a hot min then it turns off. Nothing happens after that. okay. well my dell laptop isnt turning on. the battery is tottally charged and everything. its not the battery because i put my battery in my sisters and it worked for her. and i put her battery in mine and it didnt work either. when i push the power button to turn it on the power lcd light went on. but then it turned off. please help.
  • 40 Answers
Possibley it could be some internal parts. Please try run the onboard diagnostics by holding down Fn and the power button. Make a note of the 3 lights above the keyboard (9,A and the lock key). If it starts for a second and then shut's down, the MoBo will ahve to be replaced. 1501 has known issue and I know this as I work for DELL tech support. Call tech support or chat with them...If the product is under warranty, you should get a replacement.
Pardon my spelling mistakes!!! Let me know if the information was useful or not.
Posted on Sep 17, 2008
My computer did a similar thing yesterday if not the exact same thing. When powering on the computer, I could hear the fan and DVD drive come on momentarily....then silence. The only light remaining illuminated was the Power light. Battery was charged and the power adapter was working. I removed the DVD drive = no go. I reseated the hard drive = no go. I reseated the memory = no go. So, I did what I do best. I took everything apart. I even took the heatsink off the processor. (I don't know why. I just did.) I guess I was looking for moisture, burn marks, or something. I found nothing and reinstalled everything. Afterward, my computer started up and it works fine. Since I don't know what fixed it and I suspect it may happen again, I will invest in that expensive laptop I've been longing for. Who am I kidding? I'm too cheep.
Posted on Feb 19, 2010
  • ymelove May 21, 2011
    Hi Txmunger, Tnx buddy! it worked. yet again, as you have said it, I didn't discover which part of the solution fixed it. but it worked fine. I called it Txmunger theorem. Hey folks, if you have the same problem with your laptop, I suggest you to use Txmunger theorem to resolve it.
    Tnx Again txtmunger
  • 148 Answers
Try removing the battery, then plugging it in and power ON the laptop without that. Maybe the battery or the battery terminal is shorted out.
Posted on Sep 14, 2008
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I have a dell Inspirion 9400 and it won't start. When I press the power button, all that happens is the power light and the dvd player light comes on and about 3 seconds it turns off. Does it with and...
It shows no power on your laptop but it shows you the dvd player led comes on then off. I would suggest try the following:
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well. 2. Make sure AC Adapter is not yet connected to the laptop. Press and hold on the laptop's power button for 10 seconds to drain the power flea. 3. Connect the AC Adapter to a known good power outlet, check AC Adapter power LED if it is on. Try to sense if AC Adapter is not making a bit of noise when it is plugin to the wall power outlet. 4. Connect now the AC Adapter to the laptop. Check if AC Adapter LED stays on when it is connected to the laptop. If the LED stays on means the AC Adapter is fine. If the AC Adapter LED turned off check the AC Adapter pin that goes to the laptop AC socket if it is loose. 5. If AC Adapter stays on after connecting to the laptop try to power on laptop. If no power LED comes on then this is motherboard problem. 6. Before replacing the motherboard there is one checking needs to do. If you can open your laptop bottom part then good, do this when laptop is not connected to any power source. Try to reseat the laptop CMOS battery then try to power on laptop after, if still fails then replace motherboard. I hope this helps.
Dec 12, 2009 | Dell Inspiron 9400 Notebook
Cannot get my computer to turn on
remove all external peripherals. remove laptop battery. remove ac adapter.
plug ac adapter to wall power socket without the laptop connected check if the ac adapter led will stays on. if yes then connect it to the laptop and check if the ac adapter led turns off. if yes motherboard laptop has problems and need to be replaced.
if ac adapter led stays off without connecting laptop, try different wall power socket, if still ac adapter led is off then replace the ac adapter.
if ac adapter has light stays on then connected to laptop but laptop cannot even power up even the ac adapter led is on then laptop motherboard needs to be replace.
Dec 09, 2009 | Dell Studio 15 Laptop
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Notebook plugged in. cannot get the dell to turn on. its not the power suppy that i plug into wall
1. remove all ext peripherals
2. remove battery
3. plug ac adapter to wall socket power (without the laptop)
4. check if the ac adapter led stays on, if yes then connect the laptop, check if the ac adapter led turns off after connecting to laptop, if not then turn on the laptop if still no power then have replace the motherboard.
Oct 15, 2009 | Dell Precision M60 Notebook
My charge light constantly flashes orange and my C600 won't turn on at all. I hold the power button and all the lights turn off. I got nothing. Just a blankscreen.
When you say charge light, was that the battery led light that you were referring to or the power button?
If it is the battery led light, try this:
Try to power on your laptop without the battery in your laptop.
take out the battery and just use the ac adapter, if it works fine then there could be a problem with your battery.
If is the power button that is flashing orange, then try to power cycle laptop.
turn off laptop.
take out the battery and the ac adapter.
then while those are out, you hold down power button for atleast 10-15 seconds.
put back the power source and check the led again.
Apr 08, 2009 | Dell Latitude D600 Notebook
Dell latituded600 charger lcd off,
Ok... that makes a little more sense... Here is what i want you to check... Disconnect the AC Adapter from the system and plug it into the mains, check the LED light (Should be Green). Then plug in the connector to the laptop, check the LED. If the LED turns off when you connect the laptop. Your Laptop motherboard needs to be changed.
Jan 14, 2009 | Dell Latitude D600 Notebook
Sounds like you have short circuited your Motherboard badly. This will generally cause laptops to quit functioning at all. Get it replaced. Really is the only option.
Hope This Helps
Aug 03, 2008 | Acer Aspire 1690 Notebook
Dell Inspiron 1501 Notebook Logo
2,252 people viewed this question
Alun Cox
