Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
Will not turn on
My iopod,( model 20GB) will not turn on. It is fully charged. When i turn it on the icon flashes on a little sad face and exclamation point,then it turns right back off
  • naimesht Oct 26, 2008
    sad face on my ipod 20gb
  • poojamodi11 Nov 20, 2008
    when i switch my ipod click wheel special edition u2 after the apple sign a sad face appears and says connect to ipod.com/support/ipod
    Problem Solver:
  • 11 Answers
If the sad face appears on your ipod, it means it is broken. It needs to be taken into Apple to have it repaired or you might have to buy a new one.
Posted on Nov 16, 2008
160gb classic
iPod Symbol Meanings
The Apple iPod personal media player uses a set of symbols to communicate what's happening to the device: when it needs to be recharged or when it's experiencing problems.
Sometimes it's not obvious what these symbols mean; problems with your iPod may cause conflicting or confusing icons to be displayed.
Folder with an Exclamation Point
This suggests that your iPod can't read data stored on it.
Your iPod may simply not have enough charge in its battery to read its hard drive.
If recharging it doesn't help, you can try connecting it to your computer, then updating it with the latest version of the iPod's software.
If none of this works, you may have a dead hard drive; your iPod will need to be repaired.
Battery with an Exclamation Point
A battery with an exclamation point usually just means that your iPod needs to recharge.
Once the battery has charged up again, everything should be fine.
You can charge an iPod through a FireWire connection to a computer, but not if the computer is in sleep mode or switched off.
Third-generation iPods cannot be charged via USB 2; later iPod models can, however.
If you are having problems charging your iPod, try switching cables.
You can also try resetting the iPod by pressing Play and Select together (Menu and Play on earlier models).
If none of these methods help, your battery may need to be replaced.
Empty Battery
If the battery icon shows an empty battery, this means that your iPod is almost out of charge and needs to power up.
If you know that the iPod has been charging for a while, and the battery icon is still empty, you may need to update its software.
Older software can lead to a confused battery readout.
Wall Plug with Power Adapter
This means that your iPod needs to be plugged into an electricity supply while it updates its firmware.
You won't be able to do anything else with it until you do this.
Frowning IPod Icon with an Exclamation Point
A picture of an iPod with a sad face and x-ed out eyes plus an exclamation point indicates a very serious problem with the device.
In some cases, draining the battery completely then recharging and resetting the iPod can offer a short term solution, buying you enough time to back up your iPod's data.
The underlying problem will remain and is likely to get worse until your iPod is repaired.
Apple Logo
A brief appearance by the Apple logo when the iPod is reset or switched on is normal and nothing to worry about.
If the logo does not go away and the iPod doesn't boot up, there is a problem.
You can often resolve this by putting the ipod in Disk Mode and then restoring or updating its software; note that you will lose all data stored on the iPod if you do this.
If this doesn't work, your iPod needs specialist attention.
Do Not Disconnect
It is not safe to unplug your iPod when you see this icon. Wait till it goes away, then you can safely disconnect your iPod.
Spinning Disk Icons
The spinning disk and magnifying glass icon means that the iPod is performing a disk scan.
If you don't want to perform a scan right now you can re-set the iPod; you'll see a disk with a cross when you stop the scan.
If you would rather let the scan complete, you should connect the iPod to a power source as scanning drains the battery.
If the scan finds issues but can fix them, you'll see a disk plus an arrow.
If everything is alright, you'll see a disk plus a checkmark.
If there is a problem that the scan disk function could not fix, you'll see a disk plus an exclamation point.
Ipod shows RED X
http://support.apple.com/kb/ts1463
Resolution
Restore iPod from Disk Mode
Jul 26, 2013 | Apple iPod MA446LL/A MP3 Player
Flashing icons while charging... am I really charging?
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod (located on the logic/circuit board) has died/failed and needs to be replaced. If you plan on replacing this part, you may also need to purchase and solder a new battery to the iPod logic board if you were to do it yourself.
May 26, 2009 | Apple iPod nano
Ipod showing sad face
There is a free video on the Sad Face icon issue at the following web address. I hope that it is very helpful to you.
http://fixyouripod.weebly.com/
It is the first video on the page, just scroll down a little bit. :)
May 08, 2009 | Apple iPod shuffle MP3 Player
MY IPOD IS SAYING GO TO WWW.APPLE.COM/SUPPORT/IPOD
If the iPod is showing the "Sad iPod face" icon, this means that the hard drive inside the iPod is dead and needs to be replaced.
If the iPod is showing the "Folder/Exclamation Point" icon, this means that the logic board (the circuit board) inside the iPod is no longer working properly and needs to be replaced in order for the iPod to work.
Feb 12, 2009 | Apple 20gb Ipod Mp3 Player With Click...
Can't use my ipod 20gb
Can you charge it? If so fully charge it and then connect it to the computer and reset/rebot the ipod and see if that helps, if you can't charge it just do the same thing.
Dec 11, 2008 | Apple 20gb Ipod Mp3 Player With Click...
IPod does not charge
Search for 'The iPod battery Unplugged' it will probably help you diagnose the problem cheaper than apple will
Nov 27, 2007 | Audio Players & Recorders
My iPod (4th gen 20gig) seems to have died... when you switch it on the apple logo appears then a folder with an exclamation mark... It also isn't recognized when you plug it into the PC...Also I have seen...
battery is not the problem, most likely your hard drive is bad, or motherboard is defective somehow, try open the ipod, and disconnect the battery, see if hard drive connector is installed properly, then plug the battery back and try to turn it on, helps 50/50, if not - replace the hard drive
Aug 23, 2007 | Apple iPod MP3 Player
Ipod model MA079LL do not want to turn on
Has the problem been resolved? If so, congratulations!
May 24, 2007 | Apple iPod MP3 Player
Charging icon
For windows users "When you plug your iPod nano into a power source, the charging icon appears?it's a lightning bolt over a battery. Depending on the state of the battery, it may or may not animate (flash between gray and green). In either case, the icon indicates the battery is charging successfully. When the battery is fully depleted, the iPod nano may not appear in iTunes until it has been charged for about 10 minutes. The non-animated version of the icon, shown above, appears when your battery has been fully or nearly depleted of charge. This appears for up to 10 minutes. Note: If your iPod nano is connected to the computer, the computer won't see it until after that 10 minutes has elapsed. After that, you'll see the ""Do not disconnect"" screen. Here's the animated version you would see after 10 minutes, or when the battery is not fully drained: If the charging icon is flashing and your computer doesn't recognize it, Can't see your iPod in iTunes or Windows Explorer? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below?you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. iPod appears in Windows Explorer but not in iTunes or iPod Updater If your iPod shows up in My Computer, but iTunes and iPod Updater don't recognize it, there may be a software conflict, or iPod Service didn't load. You may see an ""iPod Service Error"" alert or a ""Please Reinstall iTunes"" message. If you see either of these messages, try the solutions in this article to resolve the issue. Laptop or portable connecting via USB? See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh
Sep 28, 2005 | Apple iPod nano
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
147 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
