Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture, no sound
My stand by light blinks 7 times, pause and then seven more times etc. The TV worked fine, we turned it off and now can not get it to turn back on. It acts like its turning on but does not. I've unplugged and waited 30 min. with no change. I did get the system to change from 7 to 6 blinks once. The set is approx. 5 years old and it took four grown men to move it (almost killing one guy) so taking it to a service center is out of the question. In looking at this site others are having same issue. Any help would be appreciated. My model is a KV40XVR800 this is not listed in the drop down product menu so I just picked the closest one.
Wade
  • tracireuter Sep 15, 2008
    We have the same exact problem, except it blinks 5 times. This just happened last week, and the TV is too big for me to move.
  • Wabe Sep 15, 2008
    Sorry fat fingers, it is an XBR not an XVR. I left it unpluged over night and when I got home pluged it back in, it worked. So I kept it on for 3 hrs and then turned it off, wiated 10 sec. and tried to turn back on, it workes!. The day it was giving me problems was very humid, real high dew point and the set is next to a window. I'm suspecting that this is a short term "happy time" so this week I will try and get it out of the corner and the back off.
    Wade
  • 4,234 Answers
I don't have a listing for your model, so I'll need to research this one a bit. The 7 blinks usually mean a high voltage shutdown though. Check the regulator IC on the power supply board. Once I find the manual for this, I'll try to get you more specifics.
Dan
Posted on Sep 15, 2008
  • ABRsvcs Sep 16, 2008
    Look for poor solder connections on the main board. If you can solder, resolder any connections that appear grainy or have rings. That may resolve the problem even for humid days! :)
    Keep me posted.
    Dan
Our Trinitron KD-27FS170 Tv will not turn on. It sounds like it is turning on/off but no picture or sound. The Stand-by/Timer red light is flashing 4 times, pause, then 4 times, etc.
This typically means you have a bad capacitor, you can inspect for any swollen or bulging capacitors however unless familiar with desoldering boards best leave it to a repair technician.
Jan 13, 2015 | Sony FD Trinitron WEGA KD-27FS170 TV
My tv whe I turn it on will only stay on for 4 seconds and then turns off, and the stand by light is on and blinking.
Have you when set turns off and standby or power light flash to count here the blinks if in a sequence like seven blinks, pause etc? This se should have the error buffer.
Dec 09, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The dish washer starts to fill then stops and starts again then stops and the red light blinks on and off
Does it blink seven times, pause, then seven times, pause, seven times, etc. ?? If so you may have a bad heater element. Or the water temp into the D/W is not hot enough. Most machines require at least 120 degree water to work properly. Take a close look at the heater if it looks ok you'll have to check it and the heater circuit with a meter. Turning the breaker off for 7 to 10 minutes will reset the control board but wont fix the heater of course. Good Luck
Mar 12, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Red LED light blinks 7 times when the set is turned on; no pictur
if you have the circuit diagram of your tv,check the horizontal polarisation IC closer to the line transformer and replace it.If it doesn't work,send the question again.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega trinitron(1999) KV-36FV15 Moved tv now audio no video
Seven blinks, pause, seven blinks, etc. means "Horizontal deflection stopped" and indicates a serious problem, probably on the D or DZ board (whichever is applicable).
If this is the case, the TV will have to be serviced by a professional.
I hope this helps :)
Best Regards,
James
Jul 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Sony Trinitron 2002 Model # KV-32HS500 stand by light blinks 7 times, pauses and repeats. No picture or sound.
7 times blinks shows problem in Horizontal Deflection stage of tv and possible defective part can be Horizontal Output Transistor or Fly back Transformer.
If your are qualified tech person then go ahead to check above parts.
Sep 17, 2008 | Sony Televison & Video
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
