Question about Kenmore Dryers
Kenmore dryer mod 66822692 The heating element heats up before the start button is pressed. can you tell me which switch is at fault?
  • 958 Answers
Its the switch on the motor.
it has a mechanical interlock where in the heater should not be energize if the motor is not running.
that is the defective part. the contacts could have been welded together.
tnx 4 using fixya,
drcool
Posted on Sep 14, 2008
When you push start button it starts but wont stay running have to hold start button if we wait a couple hours it will rrestart
possible faults
timer or circuit board
the start button its self
heating element
less likely
door safety switch
May 19, 2016 | Kenmore Dryers
My Kenmore 500 series electric dryer seems to be heating, but just stopped running. I hit the start button, and the drum heated up, but did not start turning. I'm guessing that the start switch is not...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 14, 2010 | Kenmore Elite HE4 Electric Dryer
Hello
You are sure the element heats up? Belt around drum tight? Drive motor getting power from relay
Mar 09, 2010 | Kenmore 63942 Dryer
I have a Kenmore Dryer mod. 96281100 which runs but no heat. I tested power input at 240v, thernal fuse closed, thermal hi temp closed, element closed and not grounding, thermostat cut-off closed, and...
If you have 240 VAC across the element, but the element is not heating, then you have a bad element. If you don't have 240 VAC at the element, then work your way back with the voltmeter to find where the voltage is dropping
Nov 11, 2009 | Kenmore Dryers
My Kenmore Elite Electic dryer mod #11063012101
OK .. on your dryer it does have a bi-metal switch that turns on and off the element....if your dryer produces heat... nothing wrong with element.. a thermostat w/wire sensor is the only way to check for your heat if its working correctly.. the other is to check if your clothes coming out of your washer is it wetter then before.. might need to spin one more time.. good luck..
Jan 13, 2009 | Kenmore 62602 Electric Dryer
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
80 series front load dryer will not turn.
It almost has to be the belt as the heating element won't come on without the motor turning.
Jun 26, 2008 | Kenmore 62802 Electric Dryer
Dryers Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
