Question about Zoom (56600000) Router
Connection - Zoom Wireless-G AP+4, model 4401
Router set up on laptop, it is showing that it is conneted to the router (bottom right hand corner of screen) but it will not connect to the internet. Please help, no good on the technical side of things & don't understand computer jargon. Thanks Cathy
  • 8 more comments
  • nicholasload Oct 05, 2008
    Its the same with me, no internet recognition. Although now it can't even access the 10.0.0.200 either.
  • Anonymous Oct 06, 2008
    i can get the router set up but cant access the internet wired or wirelessly. am i supposed to use dhcp or pppoe?
  • Anonymous Oct 16, 2008
    will not connect from my laptop to internet nor can i access the site 10.0.0.200 this is so frustrating, what now
  • Anonymous Oct 17, 2008
    the internet isnt working on wireless
  • illad420 Nov 21, 2008
    Same problems with models 4420 and 4400. I can get in ONE time to the access panel. Then if I change even ONE thing on my router, I am unable to re-enter the access panel. I have a Net+ cert. And I had to pick my damn brain just to set up the 4400 with WEP. It doesn't work like it says it does in the instructions. Not with a ps2 anyway. You actually have to assign it an address and do everything manually from your provider. You can find this info from a simple /ipconfig /all on an existing connection....This was the only way i got it to work with WEP. Then I changed the MAC address on my router and now the thing won't connect again...and alas, same problem with 4400 as the 4200...I can no longer connect to 10.0.0.200. I called tech support, boy was that a joke. Someone help has anyone got this thing working? I have heard roomers that trying to reconfig on a different computer will allow you to access the control panel? But I don't see why that should make a difference. I even uninstalled and reinstalled my ethernet device from my device manager. No difference. No connection....HELP!!
  • hush47 Dec 05, 2008
    yes,exactly as above..4401,cannot access the setup wizard with the http address.
    very annoying!
  • Anonymous Dec 10, 2008
    I have the same problem, have followed everything, when I have the router connected by the yellow lan cable everything is fine as soon as I disconnect to become "wireless" nothing, I loose the connection. Have done the whole switch on and off etc can someone please help Jane
  • nathanyuh Jan 15, 2009
    evertime i type in 10.0.0.200 i get nothing. what shall i do.?
  • andrew_adela Feb 25, 2009
    i have a problem setting it up can u show me an easy way to set it up
  • TwoWS May 11, 2010
    I have the same problem, but when I type in the 10.0.0.200 or follow your link above I still get nothing.
    What am I doing wrong?
1. connect your router to your laptop/pc with ethernet cable
2. it should automatically connect you to the internet under vista
3. now open a web browser (IE, fireforx or opera) and type in the address bar 10.0.0.200 (it will bring up the firmware software of your router)
4. in the first interface click setup wizard from the left
5. click next, select router/AP
6. click next, set your time
7. click next, select DHCP client as WAN access type
8. click next, do not change this and keep the default (default is Bandp 2.4ghz(B+G), WO: AP, Network type: Insfrustructure, SSID: Zoom, channel: 11)
9. click next, select WAP2(AES) as encryption, passphrase as pre-shared key, type a passphrase/password (write down these important information, u will need it later), click finished
10. open network and sharing centre (in vista), from the left select connect to a network (make sure your wifi switch is on)
11. you should see zoom, right click on it and select properties from the menu
12. go to security tab of this menu and select WPA2-personal as security type, and AES as encryption type (some XP do not support AES, in that case you will have to select TKIP, thn again you need to go back to step 9 and change the encryption type)
13. type you password exactly you typed in step 9 (CASE SENSITIVE), click ok
remove the ethernet cable, it should connect to internet wirelessly, if not try turning off the power of both the modem and router for 30-50 seconds. this will make them adapt to new setting.
Posted on Dec 22, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Cathy I have the same make and model maybe I can help. I speak both Tech and Non Tech so stop me if I lose you.
1. Did you go through the set up process of first connecting to your wireless router through the cable provide via your PC/Laptop?
2. Congfiguring your wirless via your browser http://10.0.0.200 ?
Posted on Sep 29, 2008
I want to connect with my router, But I can't do it. My wireless router is right now working good can you help me ?
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Sep 15, 2010 | D-Link DI-524 4 Port Wireless-G Router -...
How to connect laptop to netgear wireless-g
May 18, 2010 | NetGear DG834G Router
My zoom adsl x5 modem/router will not let me go wireless
Mar 09, 2010 | Zoom ADSL X5 Router (5554-72-00)
Get my laptop to pick up the zoom router
Click Here
Jan 16, 2010 | Zoom (5590-00-03) Wireless Router (G66115)
Laptop can't read my connection.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
Jan 12, 2010 | Linksys Wireless-N WRT150N Router
Pleasssssssssse help : on router G624T
Jan 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I cannot connect this router to my wireless laptop i am with virgin broadband the desktop pc works with cable into back of pc but cannot see laptop on network
Jan 07, 2010 | Belkin (F5D8231-4) Wireless Router...
I am using a Belkin router and I cannot connect to Internet
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Jan 05, 2010 | Belkin (F5D7231-4) Wireless Router
I have a desktop and laptop mac and I cannot use my router one the laptop. I can access internet by connecting the router to my comcast cable network and to the desktop but not the laptop
Click Here
Dec 21, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I cannot connect wirelessly to my account.
Dec 15, 2009 | Belkin (F5D5231-4) Router
Zoom (56600000) Router Logo
2,387 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
